Top Rebuild this Winter
#32
RL Technical Advisor
Nice pics, Glenn!!
The rocker shaft seals were never used in production so you will not see them in a factory-built motor. Those were/are RSR parts and highly recommended for all of these engines to prevent rocker shaft leaks due to damaged rocker shaft bores.
I will be sending you a set with the complete gasket kit.
#33
Its been a while since my last post, after discussing the condition of my cylinders and pistons & so on, with Steve Weiner i decide to peel the onion way back
i ended up getting Steve to rebuild the heads/valves , rods, rockers and supply me with new pistons, cylinders bore the heads for head gaskets
Satz bearings
heads rebuilt
intake valves
machine heads for gaskets
Viton gaskets set
had the crank polished and checked for size, it was bang on
Steve has been a great help to me
here are a few picks coming back together
Satz bearings
heads rebuilt
intake valves
Viton gaskets set
#35
also decide to rebuild the slave cylinders with the new seals from NineMeister longitudinal & lateral actuation cylinder seal kits
i don't think mine were working seals were really stiff and hard, spring wasn't retracting at all
glenn
glenn
#37
Here is the other cylinder slave (side of trany) it differently needed rebuilding again im sure they were not working
when i had the slave complete i tested it using my finger in one end and compressed air in nipple end making sure the piston traveled freely back and forth
glenn
glenn
#41
I keep telling my self, I can do this too, but honestly, I don't thinkmI could pull an engine rebuild off.
I worked with my father when I was 18, to rebuild the engine on my 1st car. It was great experience but many, many years on, I don't think I'd have the patience and and ability, so, much respect to you guys that can do it yourselves.
Having said that, I'd love to it again with someone who really knows what they are doing.
#43
thanks comrades i did make my share of mistakes when i was young, i remember rebuilding my 72 Opel GT 4 cylinder, i did so many things wrong im supprise it it ran at all, blue smoke was worse after then before lol
patience, books and help from Rennlist, Steve Weiner & Youtube (RedTek)
helps immensely lol
PS my dad was a great teacher too
best
glenn
helps immensely lol
best
glenn
#44
Great to see things progressing and now the exciting part putting it all back together. Thanks for taking the time to share your pictures and comments. Excellent thread!
#45
Nice work Enso,
I just did this myself and documented the engine assembly for my 964. Feel free to take a look at our website at the preview videos if it helps jog your memory in some areas, like timing the cams, etc.
I think you got it though, keep up the great work.
Denis
www.pfixit.com
Denis
www.pfixit.com
