Steering rack bleed procedure
I just finished rebuilding my steering rack and will remount it tomorrow. The only thing I am unsure of is how to bleed the rack. Is there a DIY out there?
Fill up the reservoir and upen the banjo bolts?
Hi cobias, yes I posted in the klaindustries thread. The seals provided were perfect. After installation the steering felt a little "harder" but no leaks so very satisfied.
Morten, I read your post afterwards. Glad they fit in for you and thanks for posting the rack number also. I got my kit from the place your friend did. I might have time between now and the next weekend off to try and get mine done. I just took care of several other things this past weekend. k40 radar detector front mount, shifter bushings, and used a spray product found on one of the forums to refresh my tail light lenses. I have noticed that the reservoir is finally changing level for the power steering so that moved it up in line a notch. Good luck with yours and thanks again for the input on the other company.
