964 Forum 1989-1994
Odometer
Old Jul 22, 2013 | 12:53 AM
rhyd911's Avatar
rhyd911
Default Odometer
Decided to finally tackle the problem of my odometer not working.
After reading up on the topic I thought that maybe the pod gear had dropped a cog - the reality is a bit more dramatic...
File Type: jpg
Old Jul 22, 2013 | 04:40 PM
David A's Avatar
David A
Contact them: http://www.nhspeedometer.com/
Old Jul 22, 2013 | 05:21 PM
Ken D's Avatar
Ken D
You can replace the gear or pod separately. Pelican carries them.
Old Jul 23, 2013 | 07:38 PM
PelicanParts.com's Avatar
PelicanParts.com
Basic Sponsor
Odometer gears & pods for your 964 are available. Make sure you confirm the correct gear & take a look at the odometer gear replacement article as well, it's a good read.
964 Odometer Gears & Pods
Let us know if you have any questions.
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Jul 23, 2013 | 09:48 PM
964Heaven's Avatar
964Heaven
heres a repair diy with links to sourcing those gears
http://p-car.com/diy/odometer/
Old Aug 3, 2013 | 07:03 AM
rhyd911's Avatar
rhyd911
Great advice all round guys. Sourced new pod and gear and all is now working as designed.
Old Aug 26, 2013 | 04:56 AM
Rey Gunn's Avatar
Rey Gunn
Great thread! I just bought my first porsche and the odometer doesn't work. From reading the posted links, I believe I ruined the gears in the odometer when I pressed the pin to reset the trip meter. This is going to be my first DIY on my new to me car. Thanks for posting the links and how to. This place is a wealth of info.
Old Oct 6, 2013 | 06:09 PM
jimq's Avatar
jimq
Burgled
I need to replace the bigger of the 2 gears in my speedometer. I had replaced the small gear about 5 years ago and its worked fine until now. The gear I need to replace is totally gone in a dozen or more pieces so no chance to count the teeth. I have a 91 TIP. has anybody else replaced the bigger gear on this year and TIP ? They have a 16 or 17 tooth choice and there is zero chance of counting anything. The small gear is 15 teeth if that matters.
File Type: jpg
Old Oct 7, 2013 | 02:03 PM
jimq's Avatar
jimq
Burgled
Ok so I called odometer gear today and they told me if your eaten up big gear is reddish like mine its a 17 tooth gear. If it is blue/green its the 16 tooth gear. Very helpful guys to talk to.
Old Jan 27, 2014 | 05:34 AM
jorijori's Avatar
jorijori
Hi Rhyd911,
My car is 964 Singapore & what size of gear & pod did you order? I'm guessing mine is 15 tooth gear & 17 tooth small pod based on Pelican odometer gear table.
http://www.pelicanparts.com/catalog/...l/odogears.htm
Old Jan 27, 2014 | 01:29 PM
PelicanParts.com
Basic Sponsor
That's correct jorijori. We laso have a good write-up on the procedure as well:
911 Odometer Repair
Mark/Pelican Parts
Old Jan 27, 2014 | 10:50 PM
rhyd911's Avatar
rhyd911
Hi JoriJori,
I ordered the 15 tooth gear with the 17 tooth pod.
As you can see, mine had pretty much disintegrated with all of the pieces of red plastic embedding themselves in and around just about all the gears in the odometer mechanism.
Very therapeutic couple of hours digging each bit out using just a pin and perseverance...
Old Jan 28, 2014 | 01:13 PM
jorijori's Avatar
jorijori
Hi Rhyd, thanks for the reply. One last question, how did you remove the needle/pointer?
I've done the clockface, the toughest part was putting back the outer bezel to the housing. Clock hands were not that hard to remove, just pull straight out.
https://rennlist.com/forums/911-foru...h-clock-2.html
Old Jan 29, 2014 | 10:04 PM
rhyd911's Avatar
rhyd911
iirc, applied gentle vertical pressure to the hub of the indicator needle directly perpendicular to the face and it popped off.
Old Jan 29, 2014 | 10:23 PM
540964's Avatar
540964
Veteran: Army
I just finished this repair. Following the instruction found on odometergears, the needle popped right off. I reassembled everything except putting the bezel back on because I want to make sure everything works correctly before refolding the bezel. Winter here so the checkout will have to wait. Now, back to the suspension rebuild - all new bushings are going in.
