Rear spoiler plug?
Fitted fixed spoiler sumtime ago and iam attempting to stop the warning light from lighting up on the dash.
I know i need to connect wire 3 to wire 7 ( on the plug in the engine compartment).
But there not numbered, ive searched but cant find an image to show which pins to connect togther.
Any one got a pic?
Thanks in advance.
Any one got a pic?
Thanks in advance.
Any one got a pic?
Thanks in advance.
Any one got a pic?
Thanks in advance.
http://www.pelicanparts.com/techarti...r_wing/3_7.JPG
And this is the entire install with pictures to assist...
http://www.pelicanparts.com/techarti..._rear_wing.htm
Any one got a pic?
Thanks in advance.
Any one got a pic?
Thanks in advance.
I used a chunk of the spoiler harness off a wreck to make a plug ...(keeps the plug nice and clean and sealed up nice in case you want to plug in your old spoiler again....keeps corrosion down) ....if you look VERY closely on one side or the other (I forget which) the pins are numbered...take a cloth and clean the plug off very well you will find the numbers on the inside of the plug next to the pins or the sockets they go into.....they may be very small and hard to see....but they are there...then do the connection
however if your '90 is somehow different than mine....or if your harness was somehow made by someone else and they didn't number the pins...let me know and I will take a look and let you know which colors to put together
This site is amazing. The knowledge and help that everyone gives to others is great! I'm in the middle of installing a wing on my car and came across this issue. A quick search and voila! Thanks RL!!!
