964 Forum 1989-1994
removing weight from Engine/ boot area
Old 05-16-2013, 12:39 PM
jack.pe
jack.pe's Avatar
Default removing weight from Engine/ boot area
In November I am going to get an engine rebuilt, while it is out of the car are there any parts (aside from tinware which I am already going to get redone in fibreglass) that can be lightened or removed?
also, how, hard/easy is it to change the gearbox mount to RS spec?
Obviously the fan is on the list but what other bits can be lightened?
Old 05-16-2013, 01:07 PM
freedman
freedman's Avatar
Remove rear blower fan, replace with RS duct (or block offs)
Remove airbox cover and replace with Fabspeed or cup type frame
Not much else to lighten in there I dont think
Old 05-16-2013, 01:13 PM
KaiB
KaiB's Avatar
Headers and a nice muffler will save quite a bit of weight, as will an aftermarket composite rear lid.
Old 05-16-2013, 02:45 PM
Captain Ahab Jr.
Captain Ahab Jr.'s Avatar
wevo engine mountings have to be lighter
do you have air conditioning and if so could you live without it
engine lid dampers
sound deadening, don't remove but replace with something lighter like dynamat extreme
Old 05-16-2013, 03:54 PM
jack.pe
jack.pe's Avatar
engine lid dampers
Lid dampers are already off and I have RS Mounts. Sound deadening mat could be interesting. Do we know what kind of savings could be made?
Old 05-16-2013, 04:47 PM
ALEX P
ALEX P's Avatar
I know that it's not engine but a good weight saving at the important end would probably be to go with a fibreglass engine cover.
Old 05-16-2013, 05:09 PM
timtim
timtim's Avatar
search an RS steering if you don't need your comfort solution any more...
Old 05-16-2013, 06:10 PM
jack.pe
jack.pe's Avatar
Yes was thinking about going for a ducktail but changed my mind on that... Wonder if there is a way of using standard spoiler but removing motor and gubbins and just sticking it open? And a fibreglass cover too
Old 05-16-2013, 06:15 PM
trophy
trophy's Avatar
RS Flywheel will save a 20+ lbs.
Removing Power steering and putting 997 Cup electric steering will move weight to the front.
Old 05-16-2013, 06:22 PM
jack.pe
jack.pe's Avatar
Have the RS wheel already.. Interesting on the powersteering but would not want to sacrifice feel with electric steering
Old 05-16-2013, 07:09 PM
trophy
trophy's Avatar
This is not electric Steering, it uses an electric pump rather than a mechanical pump on the engine. double benefits: Frees up 8 to 10 whp and moves weight to the front.
Old 05-16-2013, 07:15 PM
robt964
robt964's Avatar
I'm in the process of doing this very mod. Spent the evening making up a mount to hold the pump in such a way that I don't loose the ability to carry a spare wheel.
Old 05-16-2013, 07:34 PM
KaiB
KaiB's Avatar
I run a RSR electric pump...trust me, the steering is sublime!
Old 05-16-2013, 07:55 PM
s4magman
s4magman's Avatar
I too am gearing up to do the steering pump mod next. I bought the 964 mounting kit from Dawes Motorsport and already have the 997 RSR pump. All the gear is now patiently waiting for me to get my act together and start wrenching. Only thing I have to figure out is how to run the electric wiring - any advice is welcome.
Old 05-17-2013, 01:21 AM
HiWind
HiWind's Avatar
+1 .... Sound deadening? A few grams.
Is there a rear under bumper/reinforcement to be drilled/shortened/removed?
Quick Reply: removing weight from Engine/ boot area
