VW 54 front light lenses, it's alright if you don't tell anyone :D
They look good, definitely an upgraded look, but as Mr.Alex initially pointed out, they may be detrimental to actual light output and the usability of the beam pattern.
The ridges on the stock lens aren't for show.
http://en.m.wikipedia.org/wiki/Fresnel_lens
If you don't do much/any night driving, then no big deal.
I would be interesting if someone did a back to back (OEM vs clear lens) comparison of the light output and beam on a dark wall.
Keep me posted if you do want to come along and I can add you to our 911uk stand if you fancy
Chris
I don't think side-by-side will be beneficial since the beams overlap. Just take a pic of the output and beam pattern against a wall (maybe 15-20 feet away) w/ the stock setup, then do it again after you swap the lenses. Just make it so the conditions are consistent between both pics (e.g. dark wall, similar ambient lighting conditions, camera settings the same, etc.)
Mine are due for delivery today. Car will be at paint shop from tomorrow till Monday tho, so will be a few days until I can fit.
I'll get some photos up once sorted
Chris
Chris
A mate has told me he fitted clear lenses to his Westfield, and fitted a patterned reflector to ensure the beam pattern remained the same. Not sure if we could do something similar? This place sells them, about half way down the page:
http://www.classic-car-accessories.c...EADLIGHTS.html
Hi Chris,
Haha thanks. I'm based in the Philippines. Yes will post pictures of the build. Currently there will be 3 builds here in Manila and possibly a fourth RWB.
Well I took pictures of the before and the lenses are supposed to come today, however, because I'm such a simple minded bloke, I only now realize that I probably have H5's on the car.
