The (Semi-Official) 964 Driving Tips Thread
#106
I found this video very helpful... I love track driving but this is where the action is!
I guess it’s just the little kid in me that wants to take the car out in the rain just so I can practice kicking the tail out. It’s truly amazing how much control this engine layout gives a good driver.
Richard Tuthill says, "...For most people it’s back to front, but for those of us in the know, it’s about the optimum you can have for this period. It’s just a question of understanding the dynamic of the car."
"…I haven’t got a great concentration span, …so in a front engine, rear wheel drive car I’m genuinely bored in about a lap, but the 911 keeps asking you questions every second you drive it."
@ 4:10 the theory of driving a 911
As a bonus, it's the interviews first time driving a 911.
#108
#109
searching...
#111
Absolutely the same concepts apply on the track, yet speeds are increased, traction is far better and thus all of our inputs occur more gently when limits begin to get reached.
Who wants to write a bit about this???
#112
I didn't want to hijack TRAKCAR's thread, so I am posting this here.
In the First time DE in a 964RSA thread Kaib posted this:
I am very curious as to the methods one can use to accomplish this. My car ('91 coupe, about 550 - 675 lb-in springs, RS sways set in the middle front full stiff rear, camber 3° front 2.5° rear, toe about 1/8" front and rear, 225 and 255 NT01s, no LSD) is pretty loose/nervous on corner entry, and pushes quite a bit late in the corner as a I roll to throttle. The tighter the corner the worse the exit understeer is. I assume that a proper LSD could help with the corner entry nervousness allowing me to be more aggressive with the set-up for less corner exit push?
Is there something I am missing that can reduce corner exit understeer without increasing corner entry oversteer?
At some point in our track experience, some of us find that a nervous-loose car is faster, Peter may be one who finds this in his 964, given his experience with the power of his water pumper (and his track time), he may want a looser rear end from mid-corner out...a small change there helps us get onto the throttle earlier.
#113
How fast are you? Experience? Don't be shy here, because the answer depends on your response. (GREAT question btw.).
Also, is your car niddly during and at the end of braking, at corner entry while trailing off the brakes (gut check time, be sure of your answer as very few of us actually trail brake), and what brakes are using?
Let's examine the driver before we look at the car (but, yep, a strong LSD is a big deal here)
Cheers!
#114
The brakes are stock calipers with PFC 97.
Thank you for considering my questions.
#115
ValveFloat, I'm not qualified but my 0.02c anyway; Everything I read makes me think you car just pushes too much on throttle. I don't Think LSD would fix that, may even make it worse.
If you keep the nose planted and come off the brake easy with some rotation and give it a little time to settle, it should not push you off the track?
Don't know how to get rid of that in your car.
BTW, hijack away
BTW, hijack away
#116
(Edit to add: I re-read your post and must ponder the below over coffee. I do think you want a LSD for sure, but must temper my comment with a few words later after I get a chance to think. The entire "niddly during entry" phase and the concomitant use of the brakes to help rotate the car at the advanced level is one of the last things we learn to do well - any advice here must therefore be carefully considered)
Joe, I'd forgotten - you're DRIVING.
This is one of those times where, at least in my opinion, we have a case of a driver who has reached the limits of his car (at one certain point on the track)...and FINALLY...
...we get to discuss altering the car and NOT the driver.
(It's a lot less expensive to work on the driver - including the use of a pro coach, but...)
I do believe its time you installed a LSD. Get a Guard, don't think about it, it's now time to do so. Some might say that the LSD might exacerbate the mid to late corner push, but we have to work on the elephant in the room first.
Once that is done, and you can work the car with confidence at turn in, given your experience and feel, it should be easy to set the car up to do anything you desire later. Congratulations!!!
#117
I too have been struggling with getting past throttle on under steer I had gotten in a habit of getting back on the gas sooner to stabilize the rear (no lsd either) and was making the car push on exit.. I tried to take later apex and rotate car more earlier in the turn so I could unwind the wheel sooner this worked but was slower. In the video above he says you just have to come in "hotter during turn in" Kai's term nibbly or nervous the car should feel and however un nerviing that is it is what it takes, once i carried enough speed to get all 4 tires to carry slip angle it was much easier to rotate the car and steer with the loud pedal. I am still learning to do this in more locations on the track (need more courage) but on the corners I now trust it is amazing as Peter (pro coach) states no more just grinding tires away. Trail braking to achieve this is my next learning curve for sure as Ross Bentley states 4 stages "un-consious incomp, concious incomp, consious comp,un-consious comp!" rinse and repeat
A huge thank you to all that are willing to teach those of us hungry to learn
#118
Both Heath and Joe are at the point in their cars that they are actually working them. At this phase, as Heath mentions, the driver enters "un-conscious competence" in R. Bentley's terms where inputs to the car are made without thought.
The "conscious competence" never leaves us though, as we must continue to work on learning, altering inputs and determining how we can help the car go faster.
I've given Joe's question a day's thought and will stand by my comment regarding the LSD. I believe this (assuming all else is more or less correct with the car and the alignment is good) could be a huge help. We're at the level now that diagnosis and tips via the interweb become difficult as many (many) differing things all play a role the car/driver performance - but as I mentioned above, we must first work on the elephant in the room.
In Joe's case, I honestly believe we need to change the car before we continue on the driver...he's good enough to then decide what he wants the car to do afterwards.
Back to the basics, though, as this is the heart of this thread. Joe "could" have one driver error which could lead to the niddlies he's experiencing at turn-in. What could it be? (hint, as usual....it involves weight transfer)
#119
Unsettling the car due to down shifting? Incorrect heel-toe?
#120
Too hard on the the brakes leading into the turn (Not threshold braking)? Thus causing too much weight transfer to the front wheels?
