hi, new member!
Just thought id say hi. Been lurking in the background for a while and thought that now my project is in full swing I ought to share. Rennlist has been invaluable so far so thanks to everyone whos helped, not that you even knew!
Im in the process of building another rs clone, I know! Got to be done though. Ive gone pretty full on with this so far,
Full lw interiour
Pole positions
Manual windows
Hiego half cage
Cup shocks
Rs springs
Rs roll bars
Rs bottom arms
Rs engine mounts
Cup wheels
996 turbo front brake conversion, rear is in the pipeline but currently have old fronts on the back
Fully adjustable top mounts
All this is going on a 90 c2 coupe with a factory ltd slip diff which is a n ex singapore car with two owners and amazingly for such an old car is so far rust for bodge free!
The engine is where it gets a bit more exciting
Cup cams
Heads rebuilt with new guides and valves with five and three angle seats. Also some light porting of the intakes, just blending the seats in really.
Gas flowed and boat tailed cases
Rods matched and stress relieved
Piston weights matched
Rockers shot peened
Ti retainers and hi rev spring kit fitted
Crank, flywheel and pulley balanced
Rs clutch and flywheel
All new cam chains, guides and pulleys, arp studs etc
While this is going on at my local porsche indy the boss decided to make a set of roller bodies for the car which will be run by a webber engine management system which means the dizzies can go along with the airbox and all the air con stuff so should be nice and tidy in there. All cases are being vapour blasted as we speak, the heads and barrels are done and look cleaner than new so this should all build up really tidy looking.
Dont think ive forgotten anything, when ive worked out how to upload pics ill get cracking. Especially with all the engine assembly!
Hope you all enjoy this as much as ive enjoyed reading about your cars!
Manythanks, jim.
Full lw interiour
Pole positions
Manual windows
Hiego half cage
Cup shocks
Rs springs
Rs roll bars
Rs bottom arms
Rs engine mounts
Cup wheels
Cup cams
Rockers shot peened
Manythanks, jim.
You will have to bear with me a little as im a bit of a techno phobe, can I put pictures strajght up from my phone? Most of the work inc the roller bodies is being done by phillip wooley at 911 sport in lincolnshire, the balancing and other internal work has been done by nick at redtek.
Ah the brake conversion, that was one of the easy bits to do. I had nigel at powermarques make up some brackets and skim a little off the calipers and they bolted straight on with 965 (I think) turbo disks. As for the rears nigel is on it at the moment, its the handbrake that is holding things up I think. Spa would be nice but I think ill be pushing my luck with that one, definitely up for all the meets during the summer also planning a lot of track days!
Can someone help with how to upload pics, ive got some into a couple of albums but cant seem to copy and paste the bb code so I can include them in a post?
Alternatively you might already see an 'IMG link' by your album pic. Then just copy and paste that into your post.
Also as a Rennlist member you'll see below the post writing box 'manage attachments' button...you can use that to upload photos directly.
Website went down about 8 months ago and there was a lot of talk on PH aabout being unable to get a response from them
Car sounds great BTW
