Respray Time Q. Window seals
Oh no something else on the slippery slope list please dont tell me anymore, 993 door handles,3rd brake light,remove washers from bumper, remove indicators from wing,replace all body seals, now add 993 rubbers will it ever end !
That's why mines affectionally known as the money pit & I'm sure not the only one...
You get change from £30 for a cuppa T for a new 1/4 glass each if you
Want them Gaz..
And what, with my thirst i do like a cuppa.
And come to the conclusion that as i have the best colour for the 64 i don't need the 993 door handles because they already match.....
Anyway someone said if your gonna paint the alternator fan you might as well rebuild the motor while your in there?
Yep been looking at these too, even thinking of getting them and having them sprayed at the same time just in case i decide to fit em. How daft is that! I will see if i can get some pics of the car
No scratches on the windows I hate to think what the roof lining looks like! What on earth has been going on back there
Thanks Steve, Rob.
It was actually John (unit 11) who recommended the mod as they my indy for repairs and servicing etc. He did mention someone who had a front screen removed at their garage just in case the screen broke and he was talking me through the repairs and plating work. (could this be yours?)
this thread makes good reading as I plan to some how remove the screen to deal with the rust spot in the corner. Did they manage to remove screen with out cutting the rubber ? I thought did was difficult as screen is bonded well not the screen but the rubber is bonded glued to the metal surround ?
My car is a LHD California convertible import with twin airbags more then likely my screen will be glued this sucks as it makes for a harder removal..
I see so many threads with heated discussions on 964 screen rubber being glued down and some people saying it is not glued. Does any one know what the fix is for the water trap at the corners to stop repeat rust issues sorry to try to Hijack this thread but I feel it is an issue that might concern the original Poster..
The screen was removed no probs with the rubber seals intact without cutting, so thats a bonus. You have a point cbr786 about the water holding behind the screen in the corners, must have been a problem for a previous owner as there was clear plumbers silicone behind the screen under the seal! Not however if anything would help, i hoping that making the surface good again, and refitting the seal will do its job. Does make you think it might be worth and cant hurt to add some form of non setting sealant in there too, unless this is bad and i missing something.
Cbr, your probably right.
Your screen stands a good chance of being full of glue.
If its only a bit you can remove it with the rubber.
Depends how much bond is on it.
Ive seen an import 964 with 20/30 mm of bond all the way round, glass and body. Very tough to remove.
Try pulling the rubber back, can you see any glue?
