Is PSS10 or KW Clubsport suspension better?
#31
Yes, as Rob says above, there's no problem going to RS height. Mine was initially set that low but I then had it raised by 5 mm to make it more road friendly - grounding the front on speed bumps set my teeth on edge!
#34
i think you`ve to compare the PSS10 with the KW-V3. The clubsport doubles spring-rate, compared to V3. The PSS10 has softer springs than the KW-V3.
I was said from a motorsport company frontrunning on VLN at the ring, that the KW clubsport is good drivable on street and perfect on track. All fast 964-guys here say that tuning coils (like V3 and PSSxx) are far to soft....
#35
