Atlas MR-06 Midrise Lift Installed
Finished setting the lift up this evening. Very pleased with the outcome!
See here for pictures:
https://picasaweb.google.com/1001400...eat=directlink
Please forgive the poor quality photos. The cell phone shots coupled fluorescent overhead lights make the car look terrible.
Here is a link to the lift:
http://www.gregsmithequipment.com/At...e-Midrise-Lift
No affiliation other than a happy customer!
Also, thanks to Marc Shaw for the idea to build "lincoln log" style ramps that can be easily removed once the car is in the air.
Burgled
that is a great idea on the cross boards on the front. I have a board screwed to both boards keeping them from moving apart which gets in the way if i want to get under the front of the car.
You will wonder what took you so long to get one
Boy, that looks like the way to go......
How easy was the delivery/set up ?
nice lift. seems most of these lifts are designed for typical front end mounted engines. if you look your cg is way aft of the lift. i believe a rear engine car should be loaded with the other way. look in the instruction it tells that. just want you to be safe. also the rear of your car is saggging abit cause of this.
There are 2 ways around this:
1. Cut off the rear crossmember, weld plates on the sides of the cut piece so that they extend the distance of the remaining pieces of the crossmember still attached to the lift, weld on a top piece over the new plates to form an upsidedown "U", drill 2 holes thru the plates and the remaining section of the square tubing. Bolt the cut portion to the stub pieces of the crossmember. On, and on. and on, forming a rigid member again!
2. Cut off the rear crossmember.
I did Method #2 on day 1 and have had the car up and down hundreds of times and the engine dropped 3 times. However YMMV
Socks & pants it is then
Is there enough clearance in the rear to remove the engine with this lift, or would the lift interfere with the engine and transmission when dropped?
Really nice work Kyle!
I'm looking to purchase the exact same lift. Would you have dimensions or a cut sheet for the "Lincoln Log" ramp? Doesn't make sense to reinvent the wheel.
Thanks!
Greg
Thanks!
Greg
