How can I get Scantool Freeware?
7th Gear
I saw a reference to this on the Pelican board. I spent quite a bit of time running searches for the software. I've found lots of talk about it and some help using it. I've even found the interface at ToreB's site, but I can't find any source for the software itself. Can anyone point me in the right direction?
Thanks,
BTW my car is a Guard's Red '91 C2 Coupe
Thanks,
I trust that you realize that you need an interface between the 19 pin port on the car and your computer. This is referred to as the "Scantool". Just having the software is pretty much useless. It is a VAGCOM RS 232 OPTO interface module. ( sounds technical to some!)
The interface from ToreB, or someone else is a MUST!
7th Gear
