Rs rear screen weight?
12-07-2012, 03:47 AM
12-07-2012, 04:14 AM
Quote:
Originally Posted by
911nuts
Hi, Do you by any chance still have the part number for this 964 rear screen (no hole or heat)?
Thanks.
RS rear screen is
964 545 107 08
According to PET
12-07-2012, 07:25 AM
I will have a look to see if it is the same as the part above as u think that's the one with the heated bars....ta
12-11-2012, 09:40 PM
Hi, Did you get time to check on the part number for the rear screen without wiper hole and without heater wires?
Thanks.
12-12-2012, 04:21 PM
Sorry I've had a look and can't find it in my box of invoices
12-31-2012, 06:45 AM
fuch
Anybody know how much a rs screen is in weight compared to a c2/c4 wiper hole rear screen...
As just had one made with no hole/heater bars and it came out at 605 grams in laminated glass.
I thought the standard screen normally around 7.5kg so is yours actually 6.05kg?
Also does the thinner glass fit in the standard seal no problem?
Cheers
12-31-2012, 07:20 AM
Give tom a ring as weight done on his scales...
Screen will fit a 930 but you will have to use 964 rubber.
Glass thickness is same as rs rear screen so will fit fine in rubber.
12-31-2012, 08:55 AM
01-02-2013, 08:28 AM
fuch
Cheers for that - I did stop past Lemass the other day but was all closed up so will try again.
911PERVY
It cant be 605 grams!
Agreed, for it to weigh that little I think it would have to be about 250 x 250mm
01-03-2013, 12:33 PM
think its 6.05 kgs
ill re weigh it at somepoint
01-03-2013, 01:22 PM
fuch
Not sure i'm following the thread but are you saying a 964 rear screen will fit a 930 turbo? Then am I to conclude a 930 rear screen (or any earlier 911) will fit a 964?
Thx
____________________________________________________________
'93rsa 3.8
01-03-2013, 02:27 PM
964 rear screen (bigger)will fit a 930 only if you use a 964 rubber
930 rear screen(smaller)will fit a 964 but need to use 930 rubber/trims
01-03-2013, 03:13 PM
Yes, correct, the aperture in the body shell is the same size
01-03-2013, 04:13 PM
fuch
Thanks!
'93rsa 3.8
