early 964 rear shock adapters
I was intrigued by the rear shock adapters shown in this thread:
Pelican Forums.
I was then disappointed when Jeff of Rothsport said the adapter he had probably would not work for me as they were specifically for 993 PSS9 to early model 964. I'm not clear why the adapter wouldn't work for other shocks. Maybe its the way the center of the adapter is machined to fit over the top of the shock (see pictures).
We then talked for some time about what it would take to make an adapter. He said it was possible, but was it worth it??
I'd like to fit Koni's if I could get an adapter.
Does anyone know of an adapter??
Is anyone interested in an adapter if I were to get some made?? Note: I'm not sure at this point how general purpose an adapter can be made.
Ideas, suggestions?
thanks,
Dan
Pelican Forums.
Ideas, suggestions?
thanks,
Dan
I have them!
For years I have needed these. Early 964s take a different rear shock mount. They even have a different bolt pattern. I finally spent time with a friend that has a CNC and we built them. They bolt up to the late style rear shock mounts so you can use them in an early car. They are thick so it compensates for the shock height difference.
DobermanDad (12-13-2019)
IIRC the 993 uses a 4 bolt pattern vs the 964's 3. The early and late 964 have a different offset on the two closer bolts.
Originally Posted by hockenheimr
I don't think they actually make them anymore....that's what I've heard.
I.e. they've been on back order for years.
Given the limited availability of shocks for the earlier cars...
If I understand this correctly, this spacer would allow you to use any shock on an earlier car.
Can anyone confirm that?
I see these are available here: http://www.ebay.com/itm/Porsche-911-...tW2Lhb&vxp=mtr
