Some N/A intake assembly questions... Torque specs...Loctite ?
Going to finally get the stock aluminum intake installed this weekend now that I've got everything cleaned up and all the parts I needed from Sunset have been delivered. Mainly torque specs needed.
Also, on what fasteners should I use loctite and if so, blue or red?
1) The chimneys between the heads and intake runners... Is there a torque specified for the 3 nuts that secure them to the head ?
2) The breather plate and the oil pressure/temp sensor plate... 7-8 ft.lbs for the breather plate and 25-26 ft.lbs for the sensor plate? Is that correct ?
3) Torque specs for the engine carrier to mounts and carrier to engine ?
4) Torque specs for RS mounts to body ?
5) Torque specs for mounting the A/C compressor to the bracket... 21 ft.lbs ?
6) Crank pulley bolt... 173 ft.lbs ?
7) Fan pulley nut... 37 ft.lbs ?
8) Engine shroud... just good and snug?
Thanks for your help
engine mount...65
crank pulley...175
chimney's....just tighten...7-10
fan nut....37
breather plate....7-10
a/c bracket....18
all 6mm sizes...7-10
all 8mm sizes...18
all 10 mm sizes...58
crank pulley...175
fan nut....37
a/c bracket....18
all 8mm sizes...18
All those 6mm size studs in general I use 7ft-lbs as indicated above. Its the generic 6mm bolt torque spec. Exceptions are the cam chain cover nuts which the factory manual calls out to use 4ft-lbs.
