Help requested with installing N/A intake system back in car
Subscribe
Aug 8, 2012 | 12:53 PM
Shown below is a pic of the port side of an engine with numbers (1-8) corresponding to places on a bracket which hold a number of sensor plugs and other items.
Please have a look and help me correctly identify what these are and where they go. If you have any other helpful pics/drawings, please post them.
1) Not sure if anything really goes there.
2 & 3) I'm pretty sure these are correct.
4) Not sure, but looks like a fuel fitting.
5 & 6) Pretty sure these are cht and speed ref sensors and probably does not matter whether they go in 5 or 6, but would like to know their position from the factory.
7 & 8) Not sure
Also, the piece that goes between the intake runner and head (plastic piece that the injector goes in), there is a "sealing ring" on the bottom. Should those be replacing or can they be reused if they appear to be in good shape.
Derek
Reply 0
Aug 8, 2012 | 01:11 PM
#1 - This is the mount for the rear blower.
#2 - Knock sensor
#3 - Cruise
#4 - Fuel
#5 - Don't remember but CHT sounds right
#6 - Crank Position Sensor
#7 - Vent
#8 - Fuel return
Can you reuse seals? It depends on the condition of the seal. Is it still flexible? Is there any damage?
Reply 0
Aug 8, 2012 | 01:21 PM
Quote: #1 - This is the mount for the rear blower.
#2 - Knock sensor
#3 - Cruise
#4 - Fuel
#7 - Vent
#8 - Fuel return
Thanks so much !
Rear blower is not going back in so I won't worry about that one.
4 & 8) Fuel to/from where?
7) Vent to/from where?
Reply 0
Aug 8, 2012 | 01:27 PM
I can take a picture tonight.
Reply 0
Aug 8, 2012 | 01:30 PM
Quote: I can take a picture tonight.
Awesome !!! Thanks.
My intake & clewett serpentine kit won't be here for a few days, but I'm just trying to get this all sorted so I'm not scratching my head too much when it goes in.
Reply 0
Aug 8, 2012 | 01:37 PM
In general, the hook up is pretty simple, Green connector goes to green, black goes to black, and the hoses are unique sizes and you hook them up accordingly. But I'll get you a photo.
Reply 0
1- blower motor mount
2- knock sensor
3- cruise
4- fuel return
5- cht....white plug end
6- crank position.....black plug end
7- carbon canisiter purge
8- vent to carbon canister for fuel tank
Reply 0
Aug 8, 2012 | 01:40 PM
Photo "borrowed" from Pelican forum
Reply 0
Aug 8, 2012 | 01:46 PM
Quote: 1- blower motor mount
2- knock sensor
3- cruise
4- fuel return
Thanks Vincent.
Reply 0
Aug 8, 2012 | 01:47 PM
Thanks Vincent and Rob... When the supercharger was installed originally some of the items were rerouted and/or deleted. This will help figuring it all out.
Any idea on these?
Are these 3 points the mounting point for the cruise servo motor?
thanks
Reply 0
Aug 8, 2012 | 03:04 PM
I believe that's the mount for the cruise control motor.
Reply 0
Aug 8, 2012 | 04:00 PM
Thanks Rob, I'll see if I can find the part numbers for those.
Reply 0
Aug 8, 2012 | 04:15 PM
I found the part numbers, their descriptions were not helpful. Something to the effect of long spacer bolt and short spacer bolt.
Reply 0
Aug 8, 2012 | 04:19 PM
are you putting on a supercharger or taking it off !!!!
alot gets changed when supercharing these motors....
Reply 0
Aug 8, 2012 | 04:20 PM
that is for the cruise control unit/motor
Reply 0
