964 Forum 1989-1994
Frunk release
Old Aug 5, 2012 | 05:33 AM
jack.pe's Avatar
jack.pe
Default Frunk release
My Frunk release cable has broken... and I think my car is a 91 so without the emergency release
Will check later but if it does not have the release what can I do?
And where do i get the replacement wire from, presume a bike store? anyone know the length?
Old Aug 5, 2012 | 09:28 AM
Pesty's Avatar
Pesty
I'd take it to a specialist. I think they have to drill a hole in the floor.
having said that before you do which end has the cable broken? if its broke near the lever end you may be able to get some pliers on the cable?
also this has just reminded me can we retro fit the emergency cable before ours breaks?
Old Aug 5, 2012 | 02:06 PM
jack.pe's Avatar
jack.pe
Had a look earlier and there is no emergency cable. Surely Porsche should have done a recall on this if drilling is going to be the only way to open the boot...
Old Aug 5, 2012 | 03:39 PM
jack.pe's Avatar
jack.pe
I'm not very happy. Probably won't achieve anything but feel like writing to Porsche about this.
Old Aug 6, 2012 | 06:01 AM
jack.pe's Avatar
jack.pe
Default Hood rlease
Found some other posts... for anyone else running into this problem.
https://rennlist.com/forums/964-foru...ferrerid=49295
Consensus seems to be to either go in through the bottom, widening the hole or going in through the side, where the wiring loom comes through. I am going to try the latter first.
Will let you know how it goes.
Old Aug 6, 2012 | 09:20 AM
boxsey911's Avatar
boxsey911
Jack, make sure you take Pesty's advice of dismantling the handle first to check if it it's come off there. If you can grab the cable and it pulls all the way out then unfortunately it's broken at the latch.
Here's my thread about the cables which might be of help once you get it open and are onto the repairing stage:
https://rennlist.com/forums/964-foru...intenance.html
Old Aug 6, 2012 | 09:39 AM
jack.pe's Avatar
jack.pe
Checked already, it is definitely broken inside the trunk, not at handle end.
Ordered the replacement cables from Porsche, including the emergency one. Now jsut need to get the damn thing open. will not be easy.
Old Aug 6, 2012 | 04:36 PM
jack.pe's Avatar
jack.pe
Default Success!!!!!
Took about two hours but managed in the end! Went in through the passenger wheel arch. Took off wheel, then liner and got to the place where the emergency release should have been. There is a bundle of wires for headlights and so on coming from boot, took out the grommet and pulled these aside. Then had to deal with carpet that was fitted and still in the way. Used a few different metal bars, pushed through carpet and then used a long pry bar to pull it off from under the lock. Then used a boreoscope with a hook made from a coat hanger, pushed it through the hole and fiddled around for about an hour till I managed to hook the mechanism!! You cannot imagine how amazing it felt to hear the bonnet pop open! Someone advised to push the bonnet down while pulling on the catch and this definitely helped!!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 6, 2012 | 05:04 PM
Porsche964FP's Avatar
Porsche964FP
Great write up - well done. Thank you for taking the time to write it all up.
Old Aug 6, 2012 | 05:12 PM
alexjc4's Avatar
alexjc4
Well done! I can only imagine how frustrating that must have been, I bet the swear box is full.
Old Aug 6, 2012 | 05:26 PM
Vandit's Avatar
Vandit
Wow, congrats on getting it open!
Does your car not have a/c and condenser in the way?
I just added an emergency release to mine a couple of weeks ago using a bicycle brake cable. It was pretty straight forward and inexpensive. I run mine out through the same grommet as the battery vent tube.
Old Aug 6, 2012 | 05:41 PM
sc's Avatar
sc
Glad to hear a happy ending! As mine is a 90 would love to know how to retrofit an emergency release on mine. I've got plenty of spare bicycle cables laying around.
Vandit would you have pics of how you did this? Or is it simply hooking up the secondary cable on the same hole as the primary and routing it through the battery vent hole? What did you use as a puller?
Old Aug 6, 2012 | 06:38 PM
Vandit's Avatar
Vandit
sc: check this thread.
https://rennlist.com/rennforums/showthread.php?t=680870
Old Aug 6, 2012 | 06:45 PM
sc's Avatar
sc
Originally Posted by Vandit
Thanks you sir!
