Lets play some "Tell me what you see."
Oh I see, thanks for the clear up. Another thing is that as you can see from the first picture is that my cat bypass pipe has no brackets to mount to the heatshield, also in that thread there seems to be some kind of shield "defending" the valve covers and I don't seem to have that piece either. Would heat be such a concern?
As for heat shielding, these are pics of my car w/o and w/ the engine heat shield installed.
![](https://img.photobucket.com/albums/v512/PumpXRS/btd62.jpg)
![](https://img.photobucket.com/albums/v512/PumpXRS/btd63.jpg)
I'm not sure if it is super critical to run these shields. I run them for the sake of completeness but I know i've seen some folks that do not run them. Maybe someone else will chime in.
As for the shielding on the cat versus no shield on the cat bypass, this is because cats run super hot compared to a bypass, therefore it needs the additional shield. That bottom shield that looks like a skidplate is there to prevent the cat from catching grass on fire if you park the car off the road. The cat bypass will run hot, obviously, since it is part of the exhaust, but no where near as hot as a cat.
Well it makes sense about the heat shield not being needed for the bypass pipe. I temporarily put back the cat without the shield while I think of an alternative simply because it got in the way a lot. I think I might just have a shop weld a tiny extension to the cat, although I kind of don't like the idea of messing with a perfectly good pipe.
And apparently those engine heat shields are not on my car, I somewhat recall people on the forum claiming not to use them. This is some good leaning lesson for me right here. Much appreciated.
FWIW...I saw a couple of things you might be interested in.
http://forums.pelicanparts.com/porsc...3-6-parts.html Note...sorry...just noticed that this is really old but might get lucky??
http://forums.pelicanparts.com/porsc...e-2-piece.html
That was my opinion as well. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Also good to know I'm not missing anything with that plug in the trunk.
I'm pretty set on just welding on a tiny extension to the cat bypass as in the other suggested thread. And if the time comes that I want to try a different sound I'l either sell both the cup pipe + cat bypass or offer a trade.
In the mean time I need to get everything I need for a DIY valve adjustment.
Super Duper Moderator
Good luck with your projects.
Lucky guess. :P
I'm contemplating just getting another cup pipe and just to the standard bolt on with the bypass pipe. And in turn sell the OEM Cat + My Custom Cup pipe. Would there be enough interest online for an OEM cat?
As for the shields it seems like its a debated topic. Some claim its a bit of a hazard as it holds oil and traps heat increasing engine temps. But come winter time they put them back on. Decisions, Decisions.
That debate is most likely referring to the bottom "aero" cover, not the tins over the valve covers.
