View Poll Results: Has your engine been rebuilt?
Voters: 195. You may not vote on this poll
**REBUILD SURVEY** Has your car had an engine rebuild?
#32
A bit of a pessimistic post there Frank, you could say that about any given engine ever built.
Rebuild time for me will most likely be due to broken head stud or oil consumtion / leaks. Timing of any or all of these is unknown, especially as the cars are now of an age when they do not see a huge amount of usage.
What is the latest with regard to your engine, are you doing the rebuild or are you still at the decision stage?
Case and point:
Answering to the poll as mine hasn't been rebuilt - is not a long term answer as it may one day happen and therefore invalidate the Poll. Variable answer.
Answering I have had a rebuild - is a long term answer since another rebuild after is less likely and therefore the poll will still be valid. Less/ non variable answer.
To cover extenuating circumstances I've asked a few questions to be answered whilst polling and for people to update as they go. Hopefully it'll be an interesting thread for people to read regarding the whole rebuild saga that these cars have rightly or wrongly a reputation for. It may give us a greater understanding of why these cars often warrant rebuilds and the causes/ findings.
![offtopic](https://rennlist.com/forums/graemlins/offtopic.gif)
#33
Hi Frank, my white car has just turned 98k mile now and pulling strong. She has very little leak but love to get a full build like my Amazon car eventually when my Dr has time. Amazon had covered 148k but she was in fact full of life and when stripped she was all good inside. She got a full rebuild and lots of parts replaced for a peace of mind.
In the end of the day, it depends on how the car has been looked after. My uncle in HK has a 964 that has done 200k miles, and still running like a dream without a rebuild. I know a lot of these 964 leak oil, but this doesn't mean its serious or the engine needs an engine rebuild, which all new owners or potential owners are worried by. I believe through time the seals need replacing, but if people are really bothered, have a leak down test.
#35
,70,000 and still doing well. Had the tranny done because 2nd synchro needed work, clutch was replaced at that time, also a slow leaky seal that would have been hard to get to with the motor in.
I would be hesitant to buy a car with rebuilt motor unless I was sure of the rebuild quality.
#36
Top end rebuild at 81,000 miles to deal with oil leaks...upgraded to 993 Euro RS valves and Elgin Super C2 cams while I was in there. Sportcat and cup air box installed as well (already had G-pipe when I got the car). Have yet to remap the ECU but as it stands with Stage One SW chip, she pulls pretty strong...can't wait for the remap!
#37
1 Post
What would be even more useful is for anyone who has answered "not rebuilt" to also post their current mileage.
I answered "not rebuilt", and I'm at 51K kms, ~ 31K miles.
#39
Current 964 ('92 Cup) - full rebuild at about 30K miles. Initially pulled apart to fix through-bolt seals (got through 0.5 litres of oil in one day on track), then it was a 'while you're there' thing. The car has been (and still is) primarily track use; we found the cylinders were worn slightly oval, so new barrels and pistons, ARP bolts, uprated valve springs, Ti retainers, new main and big end bearings etc. Now dry as a bone, uses less than a litre of oil a year (5K miles, of which 3 are on track).
Previous 964 ('90 C2) - full rebuild at about 110K miles, due to oil leaks.
#41
Mine has 167767 kms (around 104800 miles) no rebuild yet and no signs that it would need one in the near future... but I have a big "secret account" to pay for the rebuild or top end rebuild when the need arises
#42
Hi Frank
Current mileage is 85k and I have recently been advised that I will need a top-end rebuild very soon. However, the car runs strong and isn't losing much oil according to the gauge or my garage floor. It does look a tad wet through the under tray and it has been suggested that the leak is from the head studs.
The car is due a 12k mile service in September and I am in two minds whether to bite the bullet and get the top-end build done at the same time.
I happily bought the car knowing it would need a rebuild of sorts at some stage. The fact that the car was in great condition and had a good PPI health check was more important to me.
#43
I think it is arguable if it does in fact need doing now. I am still undecided where to or not, but was thinking if you were to do it, it kind of makes sense to do it whilst the car is in for a major service... Hmmm?
#45
I think before proceeding with any rebuild recommended by our trust mechanics, we need to ask the following questions:
Does it still drive OK - good power, no bad noises etc?
How much oil does it use/leak? Cost of premature rebuild versus the cost of a few litres of oil every year.
I'm all for keeping our cars in tip-top condition, and I have money set aside for a full re-build. Clearly there are exceptions that we hear about on here, but I can't help think that the rebuild worry with our engines is way OTT and predominantly oil leak driven.
