What have you done?!?!?!?
Well, not really that, but there doesn't seem to be a good thread on all the mods and repairs people have done to their cars. Might help someone down the road when they hit a roadblock on similar tasks. the goal is not just maintenance tasks, but problem things that people might search on when they get into trouble
'92 Cab
Clear corners
Front hood struts
Engine lid struts
cut air box like cup style
Suspension swap to Turbo springs, Bilstein HD shocks
Replaced heater hose by rear tires
swapped fuel pump
repaired broke cab top support and put back together
cab top motor cable shortening
swapped radio--- not done with entire rewire- just swapped into the birds nest already there
Rear seat delete removed and lap belts installed.
Replaced reference/crank position sensor with new style connector
'92 Cab
Clear corners
Front hood struts
Engine lid struts
swapped fuel pump
Good idea! There is such a knowledgebase on rennlist, but often some of the older threads have missing pictures or just a hint of additional information you need...
89 C4
Things I have done / are underway:
Rear wiper removal
Interior carpet / sound deadening removal
A/C Removal
Engine carrier reinforcement
WEVO mounts
Cone filter / vacuum reservoir repositioning
Fuel Pump
Bilstein / H+R greens
Steering rack bushings and brace
Stainless brake lines
Brake / pressure accumulator ("bomb") bleed
Clutch roll pin / pedal cluster bushings
Rennline pedal install
Shift rod bushings
Single belt conversion
washer fluid tank removal
additional oil cooler
high speed fan switch
front control arm bushings
Front seat replacement
clutch slave cylinder
rs door cards
89 C4
Rear wiper removal
A/C Removal
WEVO mounts
Fuel Pump
Shift rod bushings
rs door cards
Things I have done:
Distributor Belt replacement
Coils, cap and rotors, plugs and plug wires ( NGK set )
Valve Adjustment
Vitoli sebring Mirrors on Aero base
Cat bypass/euro pre muffler and cup pipe.
replaced blower motor
shift sleeve bushings
complete interior removal including sound deadening and installed RS door panels and RS carpet.
Soon to be done:
KW coilovers, RS lightweight flywheel
Valve Adjustment
Soon to be done:
The list so far (in no particular order) ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
- A/C and oil cooler ballast resistor replacement
- RS bumper air ducts
- Perfect Power strut brace install into RHD (fuel sender needs to be moved for this)
- Gear linkage (angular cup & shift sleeve) bushing replacement
- Clutch pedal rollpin replacement with shoulder bolt
- Clutch master & slave cylinder replacement, and softhose replacement
- Fixed inoperative rear seat backrest flipdown button![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
- RS door cards
- Swiss cheese airbox
- Cup heater bypass + CCU-fooling wiring mod
- O2 sensor
- 100-cell cat install
- Cup Pipe install
- Spoiler curtain install
- Rear wiper replacement
- ISV Cleaning
- Distributor cap + rotor replacement
- front bumper cutting for Cup 1 wheel/tyre clearance
- RS door cards
- O2 sensor
- Cup Pipe install
- ISV Cleaning
My list in order
93' C2
plugs, wires, all filters, valve adjustment, etc(complete tune-up)
KW Coilovers
Clear corners
DASport bolt-in cage(powder coated red)
Guards Red bumper plugs
5&15mm spacers
Soon, I will have a FabSpeed dual outlet installed
93' C2
KW Coilovers
Clear corners
5&15mm spacers
keep in mind... what I'm after is kind of a DIY list, so if people run into a problem then can see who has done the same thing and be able to possibly ping that person for how they solved it.
Most maintenance items, like oil, valves, distributor cap/rotors, plugs are already well documented.
Here is my list in random order:
Lowered with B&G springs and Bilstein HD's
Subsequently replaced by Bilstein PSS9's with Gamroth adapter to fit early 964
993 door panels
Ultimate pedals
RS lightweight flywheel and clutch
Cut away airbox lid
G pipe
993 Cup 17" rims with black painted centers
Front Splitter
Getty RSA tail
Tinted windows
RS Short Shifter
Recaro Seats
DIY custom center console with arm rest
Moved stereo below dash in custom enclosure
Filled stereo opening with 3 gauges
Silver faced tach
One off machined ball shift ****
Removed rear seatbacks, replaced by custom speaker/subwoofer panel
H4 headlights
Black body trim and door handles painted body color
Clewitt Serpentine belt mod
Added keyless entry
Aero Mirrors
Somehow, still not done!
993 door panels
Ultimate pedals
Cut away airbox lid
G pipe
Front Splitter
Getty RSA tail
Tinted windows
RS Short Shifter
Recaro Seats
Silver faced tach
H4 headlights
Added keyless entry
Aero Mirrors
Dropped the engine / Trans a few times
Rebuilt the engine from the connecting rods up.
Changed from 2-pot to 4-pot rear brakes
Added SS brake lines all around
Added new brake bias valve
Installed roll cage
Installed Sparco Evo2 seats on sliders
Installed a whale tail after removing motorized spoiler
Added keyless entry
Replaced inner and outer CV boots
Replaced steering rack boots
Flipped the TIP manual mode so that Forward is downshift and back is upshift
Shocks and springs (but that's covered by others)
Added Fabspeed Dual Out exhaust and cut out the driver's side exhaust outlet on the bumper
......and the usual stuff.
Boy, I've been busy!
Installed roll cage
Added keyless entry
Thanks for starting this Hawk.
People move on though...
The 964 DIY section could be 10X bigger if we collected all the detail threads that already exist on the 964 forum. I search for different topics all the time, but I have to wade through so many random threads to find what I'm looking for (lots of thread titles - even if they are VERY helpful- are poorly named).
There's gold in this forum for sure...maybe RL needs to hire some college kids for the summer to organize the material?
Mine are mainly refurb, modification and styling, but here goes:
Knowledge on process of Front bumper plate recess shortening (to accommodate 5 digit plate), headlight washer jet deletion (RS style), Front bumper under-tray body colouring
Fitting Cup mirrors
Deleting rear wiper
Swapping rear bumper centre section (UK to US)
Arches rolled
993 aero door handles (colour coded) fitted
Refurb of interior leather including re-dye, seal ands re-colour
Knowledge on appointing someone to re-trim dash top, Centre console, Gear gaiter Door card tops in napa black leather with red stitch detail
Fitting leather stitched door pull handles and door pocket lids
Wet vacuuming & cleaning Linen carpets & trim
H&R Sport Height Adjustable Coil-over Suspension
Knowledge of polishing, splitting, refurbing etc etc split rim wheels (including 3 piece RH Turbo P and 2 piece BBS LM)
Fitting Cup mirrors
Deleting rear wiper
Arches rolled
IHI KING!
Hawk - Great idea.
My list includes
Drop/install engine on 964 C2 & C4 multiple times
Change clutch, throw out arm, clutch master & slave cylinders, etc
Repair odometer
Replace sunroof cables
Reline sunroof headliner
Install H&R Greens/Bilstein HDs
Troubleshoot high current drain on fuse 1
Replace alternator, fan bearing, powder coat fan
Rebuilt pedal assembly - replaced roll pin and bushings
Remove/replace steering rack and shift linkage bushings
Rebuilt power steering pump
Changed from 2-pot to 4-pot rear brakes & installed new 60 bar bias valve
Refinished Cup1 wheels - spray painting & powder coating
Replace HVAC servos
Replace bearing in rear spoiler mechanism
Replace gas filler neck
Remove/replace oil cooler & lines
Replace engine firewall sound mat
Engine swap between 1990 & 1991 964s
Install H4s and relays
Various maintenance items include oil changes, valve adjustments, brake service, etc
I'm sure there is more that I'm forgetting. I'll edit this list if I think of them.
My list includes
Repair odometer
Replace HVAC servos
The List:
Body/Interior:
Full Cage
Interior delete/RS door panels
Sparco evo seats
Schroth 6pt harnesses
AC delete
HVAC delete
Radio delete
MOMO wheel
Immobilizer delete
RS air ducts
Suspension:
Bilstein RSR dampers, custom valved by Dan Jacobs
RS ARB's
600F/800R springs
ERP front A-arm monoballs
Mode Camber and shock tower plates front and rear
18" BBS LM wheels
RS strut tower brace
Brakes:
RS/Cup setup with PFC 08 compound
stainless lines
Engine:
Cup exhaust
Heater blower delete
Cup airbox
RS chip
Dual factory oil coolers
I think that's it, car is now 2700lbs with a 1/4 tank of gas.
Cheers, James
Body/Interior:
Full Cage
Sparco evo seats
AC delete
HVAC delete
Radio delete
MOMO wheel
Immobilizer delete
RS air ducts
Suspension:
RS ARB's
600F/800R springs
18" BBS LM wheels
Brakes:
stainless lines
Engine:
Cup exhaust
Cup airbox
RS chip
Cheers, James
It simpler for me to list the parts I have *not* repaired, replaced or simply sourced (I bought the car after 6 years in a field, remember):
Pedal cluster
Engine (not counting ancilliaries)
Gearbox
Clutch
I have touched, repaired, mounted everything else.
Pedal cluster
Gearbox
Clutch
Things not previously listed
convert to R134
add headlight washers
add rear wiper
add rear washer
add seat heaters
replace front windscreen
replace rear winscreen with Euro style w/o CHMSL
add 993 third brake light
convert to R134
add rear wiper
add rear washer
add seat heaters
Repaired glove box latch
Replaced broken rear spoiler wall
Troubleshot high current drain problem--> CCU
Replaced transistor on CCU to correct current drain problem
Replaced battery killed by high current drain problem
Installed Bosch relay into R63 for daytime running lights
