964 Forum 1989-1994
Cat replacement
Old Apr 17, 2012 | 05:00 PM
jody stowitts's Avatar
jody stowitts
Talking Cat replacement
Anyone(s) ever replace catalytic converter on car with 97k+ just for "therapeutic" reasons only. Streather book says cats function @ 60-90% efficiency depending on age, "conditions", etc. If so, any increase in power, fuel economy experienced as a consequence of repl.? Car passed emissions test a couple yrs. ago @ 89k. I'm inclined to leave well enough alone; and I'm NOT a "green" fanatic. Just curious only, and with $700+ outlay for new one am easily persuaded to indeed let sleeping dogs lie. Car is '91C2 with close to 98,000mi. Highway mileage driven @ conservative RPMs of 3100-3500 currently yields just a hair under 18mpg. Tune-up is another 4-5k mi. away. Thanx.
Old Apr 17, 2012 | 05:25 PM
Lemass Automotive's Avatar
Lemass Automotive
cat bypass??
Old Apr 17, 2012 | 05:55 PM
sundog's Avatar
sundog
I've got a few projects, and the cat delete with headers is high on the list.
I felt some butt dyno HP just from removal of the primary muffler, so I would think that removal of the cat would help. But of course there needs to be some back pressure for the system to work properly. The 964 exhaust was really poorly designed however.
Old Apr 17, 2012 | 06:08 PM
jody stowitts
No cat bypass, this a stock, everyday, non-race car.
Old Apr 17, 2012 | 06:22 PM
Laker's Avatar
Laker
If you are passing CA's Smog check as is, let sleeping dogs lie. If you want an increase in performance and don't mind swapping the cat back every year for smog check, a 200 cell race cat or bypass would do the trick
Old Apr 17, 2012 | 06:55 PM
Porsche964FP's Avatar
Porsche964FP
From several sources of good authority, the best parts to bypass on a standard exhaust for best performance results is Cat-bypass and G-pipe/ final silencer bypass combination.
Plus the sound is awesome!
Old Apr 17, 2012 | 07:16 PM
ILC32's Avatar
ILC32
I have headers that go right into the exhaust (no cat "bypass" because the cat itself is gone) and the sound is amazing.
Old Apr 17, 2012 | 07:50 PM
RSAErick's Avatar
RSAErick
I'd highly recommend letting sleeping dogs lie. You most likely will not notice any improvements in power or fuel economy. I say this because I did not notice any improvements in either when I removed my cat, with ~100k miles, entirely. A dyno may say otherwise, but any power increases due to better flow through the cat are quite minor. I'd suggest putting the $700 into something else with a better return.
Good luck!
Old Apr 17, 2012 | 09:29 PM
jody stowitts
ILC32: Reckon I'll just let it be. Re: amazing sound. It sounds (no pun) silly, but the only sound that really "turned my head" was the exhaust note on early 911's, i.e. 65-73ish. If you've got a way to replicate that, I'm all ears (no pun).
Old Apr 17, 2012 | 09:32 PM
jody stowitts
RSAErick, (et.al.): Thanks for the info, much obliged!
Old Apr 17, 2012 | 11:43 PM
Shamus964's Avatar
Shamus964
Originally Posted by jody stowitts
...the only sound that really "turned my head" was the exhaust note on early 911's, i.e. 65-73ish. If you've got a way to replicate that, I'm all ears (no pun).
catless B&B header exhaust
It's the closest soundtrack for a 3.6 and it's amazing. Getting 'that' early snarly sound from these big motors ain't easy
JMHO
Old Apr 18, 2012 | 12:21 AM
993James993's Avatar
993James993
Try a g-pipe. The sound is great. It's an easy install and the
car will pass emissions without any issues.
Old Apr 18, 2012 | 06:46 AM
rollingjack's Avatar
rollingjack
I changed original cat to 200cel metal cat. I measured exhaust noise by idle with standard and after with new 200cel cat. Standard cat was 76 dbA and with 200cel it was 82 dbA.
Car has cup pipe and second silencer.
Sound:
http://www.youtube.com/watch?v=EG2Sp...ature=youtu.be
Old Apr 18, 2012 | 07:25 AM
g60pops's Avatar
g60pops
decat and g pipe/swan neck if you can
http://youtu.be/t8DjihohHho
Old Apr 18, 2012 | 10:59 AM
ILC32's Avatar
ILC32
JMHO
That's what I'm running. It does sound really good, IMHO.
