Trick to removing ignition rotors?
How do you remove the rotors on the dual distributor? Do they just pull off? I normally search these type questions but I only have access to a smart phone at the moment.
TIA
TIA
Yes, they come straight off with a tug.
They do not twist off!
Someone more experienced than I may have a trick to budging stuck rotors.
(I've never had one that stuck...)
Good luck, sir!
Good luck, sir!
Mine pulled off hard also. The new ones I installed wouldn't go on all the way, I couldn't get the caps to set down properly. I had to take a small file to the "key" inside of the rotors to make them fit all of the way down to where they should be.
Ok got them off a little force was needed. Another question where do you apply and much Bosch grease on the rotors. Do you also put some on the cap arc points?
I didn't get any of this grease. Is it necessary? Can I get it at Autozone? What's it called besides "Bosch grease"?
Another question, is there any way to make the ignition wires easier to remove from the distributor caps? I swear i'm afraid I'm gonna break my fingers from trying to yank out some of those stubborn leads.
http://www.shopping.com/napa-grease-...iFMUeKw==/info
http://www.shopping.com/33oz-dielect...WA==/info?sb=1
http://www.shopping.com/pro-honda-di...FvtJJow==/info
