coil alternatives
When replacing an ignition coil, use a replacement coil which has the overall
electrical characteristics as the original one, i.e. primary resistance, primary inductance, and turns ratio. A number of commonly available coils with their characteristics are presented here under 'Typical Ignition Coil Values'; Diagnostic
Loren, thanks for the input but.... where is "here" in this context?
TIA!
Nevermind, "Here" is HERE.
From Loren's page:
"Typical Ignition Coil Values
Bosch TCI (black/silver) - R(primary) = .70 ohms, R(secondary) = 6200 ohms, N = 90, L(primary) = 3.6 mH, L(secondary) = 30 H, ~ 60 mjoules @ 6K RPM - 6 cylinders TCI
Bosch Blue Coil - R(primary) = 3.5 ohms, R(secondary) = 8800 ohms, N = 65, L(primary) = 12 mH, L(secondary) = 50 H, ~ 30 mjoules @ 6K RPM - 6 cylinders TCI
Bosch CDI (small black) - R(primary) = .30 ohms, R(secondary) = 700 ohms, N = 78, L(primary) = .20 mH, L(secondary) = 1.2 H
Bosch CDI (small silver) - R(primary) = .70 ohms, R(secondary) = 720 ohms, N = 63, L(primary) = .40 mH, L(secondary) = 1.6 H
MSD Blaster (8222) - R(primary) = 1.1 ohms, R(secondary) = 4700 ohms, N = 95, L(primary) = 4.2 mH, L(secondary) = 38 H
Perma-Tune - R(primary) = .90 ohms, R(secondary) = 10000 ohms, N = 125, L(primary) = 4.7 mH, L(secondary) = 74 H"
Any idea what the specs on the 993 coils are?
From Loren's page:
this is based on no real facts apart from no-one reporting problems based on my memory in the last year or two, but i tend to think the silver coil thing is a myth anyway, so probably not ... but having 993 coils in the back would be a nice feeling
"but i tend to think the silver coil thing is a myth anyway"
Actually there were problems, but that was over five plus years ago.
I've verified a number of situations back then. Most likely Bosch fixed
the problem, as none have had problems for many years now.
