Front blowers DIY
If your car is equipped with a/c, the drivers (left) side is definitely harder to do than the right side. On mine I had to evacuate the a/c system and move the 2 lines out of the way to get enough space to take the fan/motor out.
I removed the driver side without evacuating the AC, and I didn't even break anything. There are some instructions kicking around about how to do this. I used a hacksaw blade as my "special tool" to depress the tabs, which worked well.
Unfortunately my lube effort only quieted it down temporarily--I shall have to try again... New fans are approaching $1000US!
Imagine what a business opportunity this could be for an entreprenurial Posche indie. Find a place that services electric motors. Supply them with a fan or two to learn how to dissassemble it and what bearings to replace and other things and then start servicing fans at the bargain price of $399 each.
Guidance requested and some experiences:
First - thanks to all that have posted and to Falcor for the great DIY write ups (part 1 and 2).
1. What is the best lubricant to use. I tried some anti-seize libricant in an aerosol and it wasn't what I was expecting. I expected it to be more like an oil and it sprays out more like a paste. I know others have suggested this, but it just doesn't seem right, so I was considering a top quality teflon libricant, but am also thinking about using the 30 weight oil idea. What is the best approach for longevity?
If I go with the 30 weight oil, how do you know when the bearings are saturated?
2. I created my version of the Porsche tool for pulling the fan from the housing and thought I would post a picture to help others. it was really very easy with a dremel and some cut off wheels - just took some time to get it right. The tool isn't pretty, but it does work quite well.
To make it I started with 1/2" and 1/4" thin pieces of aluminum from home depot and bent and cut them to fit the application.
Thanks for your thoughts on the lubricant for the fan motors.
-Skip
-Skip
I did mine when the car was stored over winter, so no rush, I added oil every 24 hours until saturated.
P.S. One of our local parts stores have a NEW left side blower motor on sale for $ 263.09, if interested, please let me know and I will hook you up. No affiliation ..............
I just phoned them, they have 3 in stock for that price, the catch is, you can only buy them in Canada. If you would like, I can buy them for you and ship to you. Shipping to me is free, but there is 12% taxes in top of the $263.09 and then of cause the shipping cost to you.
"I tried some anti-seize libricant in an aerosol and it wasn't what I was expecting. I expected it to be more like an oil and it sprays out more like a paste."
Yes, that sounds weird. How do you get a paste to sink in to the bearings? What oils are standard for electric fan bearings in other applications?
crg53 - that is a very generous offer - I'll let you know if I screw up this DIY stuff...
c didy - that is exactly my question. I'm going to use an oil and follow the recommendations from crg53 on how to re-saturate the 2 bearings per motor. I'm lucky to have a second set of them, so can clean and saturate one set and then do the swap and prep the others for the future.
-Skip
-Skip
Aerosol anti seize is a paste? How is a paste an aerosol? I can't see spraying a paste into a bearing race.
What are the alternative lubricant options here?
Just bought one fan for a RL in Australia, I think another one was bought by a RL in Toronto, so only one left at the discounted price.
C Diddy, just use W30 motor oil.
