Front disc and pad change
I'm going to change the pads and discs on the front of my 1990 C4 and this is the first real work that i'm going to be doing to my car. Whilst i'm fairly good at mech stuff (do all my own work on my motorbikes), i need a bit of advice please.
Should i first remove the calipers (not going to disconnect brake lines) and then remove the pads or should I remove some clips/springs etc first to make things easier and then remove calipers, followed by the pads. I think you follow my drift :-)
Cheers
Simon
Cheers
Simon
If your brakes have the brake dampening plates (Spiders) in place you may have trouble pulling the pads. A sharp tool like a small putty knife down the back of the pad should free them up. Look for item #20 & #21 in the picture, they are clued to the back of the brake pad, helps prevent brake noise.
Cheers
Simon
Cheers
Simon
And yes, you can remove the pads with calipers still on the car.
You have to disconnect the line. It is a hard line from the rubber line at the strut to the caliper. So it's not like a normal car... once again. I guess if you are very very careful you could remove the clip that holds the line in the strut and flip the caliper up. Just don't want to twist the rubber too far or bend the line. Then just hang the caliper up out of the way.
![](http://i32.photobucket.com/albums/d25/brksy16/964%20diy/SDC11154.jpg)
The important thing is that it shows how to remove a mushroom, which is a strange thing if you've never seen it before.
Speaking of pictures, here's one showing how Laker used a zip tie to hold the caliper out of the way.
This method worked well for me also.
One more tip....use an M8 bolt and socket to press off the rotors using the two tapped holes. Much easier and kinder than hitting them from the back with a mallet:
![](http://i32.photobucket.com/albums/d25/brksy16/964%20diy/SDC11155.jpg)
