Is this valve cover dead?
Check with Steve W. at Rennsport. He has a nice set of billet ones. Don't forget the "Valve Adjustment" gasket kit (available locally or maybe Pelican) that has all the new O-rings and new lock nuts and aluminum washers.
You'll be so psyched by the way it looks you won't even remember the additional cost... ;-)
fwiw - I just went through the same with mine. ended up buying the hargett covers - had a couple of issues with them that were overcome pretty easily - we tapped the bottom covers to accept the clips, and the connectors which I thought werent fitting right, ended up fitting ok. And then we shot them with a little satin black paint for corrosion protection and done.
If money weren't an option, I would have bought the eagle day covers. But for the price, the Hargetts were a good option. make sure you file off the sharp edges, or you will bleed. Those of you with Hargett covers will understand....lol...
