Lubricating spoiler gears
1 Post
Hi all;
I was going to try some "white lithium grease spray" on my spoiler mechanism gears - has anyone used this stuff for anything?
Apparently it goes on as a spray, then sets as grease...
I don't like that product in that area; it stays sticky and will collect dirt.
Can you get this?
DuPont Multi Use Lubricant
Can you get this?
1 Post
Thanks gentleman;
My spoiler mechanism quit working some weeks ago.
(It was recently fixed coincidentally when I replaced the cabin mounted rotary switch for cosmetic purposes.)
Whilst I was poking around trying to find the cause of the problem, I did note that the spoiler gears seem very stiff and require a lot of torque via the drive-shaft to get them moving. Hence I thought to lubricate the mechanism.
FC, not sure if I can source the DuPont stuff locally, but I will have a hunt around.
I use the white lithium in the cable housing... But that is somewhat sealed.
Foor the gears I use silicone spray since there are no rubber parts in that area. I lubricate it every 3 months when I wax the car.
Working fine this far
