Brake job going down the slippery slope
#91
can you please buy a new one of these .. the Genuine Porshe plastic part is $9 from pelicanparts .........
http://www.pelicanparts.com/cgi-bin/...0%281974-89%29
#92
![](http://www.pelicanparts.com/catalog/images/interior/ignition_sw_cover.JPG)
#93
I think other have made very good explanantion as well. Each have their own version of the backside method but ultimately from the same principle.
#94
It has been awhile since my last post. So much happened in just a few weeks. I had to attend my grand mother and my mother's funerals in only 1 month apart both in Canada. This was completely unexpected.
However, since then the motor was put back together a shinny squeaky clean.
I ended up doing a clutch job "while your in there" kinda thing. Turns out I already had a Lighweight flywheel. The clutch was a bit slipping so a new kit minus Flywheel was ordered. All I had to do was sorta clean the matting surface with a 3m pad to a smooth surface.
Also a RS single belt bulley from Rothsport was installed. I though of using the Rothsport crank pulley as well but didn't find enough info to justified the bennefits/cost.
#95
Ok, now the bad,...
After everything went back into the car, It started right up and went for a nice ride. To my surprise, the car ran good and the clutch was very clamping good and provided good accelerartion.
After only 20 minutes or so, driving around thge block, I heard a lot pop and the clutch pedal went right to the floor. Without hesitation I headed home in first, pull into the driveway and turn it ogff. I then pry the pedal back with my end, and was hopping for the roll pin in the clutch pedal assembly to have broken.
To my sad discontent, I found that it was altogether different. The clutch for mounting boss into the bellhousing fail and broke off.
Last night after work and this moring with help of a fellow Reisentoter we removed the engine and trans once more to assess the damages.
In some way, I was lucky because the new clutch disc and pressure plate were completely untouched.
#96
It has been a couple of weeks since my last update/post.
After my misfurtune with the transmission, see this link for more details and lesson learn:
https://rennlist.com/forums/964-foru...ng-boss-3.html
I then moved on and re-installed everything where it belongs. I left out the A/C compressor to loose some weight and went with a single belt Rothsport fan pulley.
#97
This weekend I had a little bit of time before my 4 wheel alignment on Tuesday (can't wait to take her for a real ride after this long winter update), and ended up taking the shark fins out for a respray. They were pitted from normal driving around. So I just wet sanded them with 500 grit, then 1000 grit, clean, spary some adhesive promoter, then basecoat and clearcoat.
Et Voila,... I also picked up a 3.8 RSR front lip from Rennspeed and spayed it as well.
#100
Dylan, here it is installed. I didnt have to get rid of the plastic valence. The lip is sandwiched between the valence and the bumper. SAll I did was to cut/remove the two plastic tabs on the edge of the valence (thos that insert into the bottom of the bumper) to ease the installation.
#101
Stephane,
I'm so sorry to hear about your mother and grandmother. My thoughts are with you and them. On the topic of your car it looks great! I'm still driving around on your old Cup 1's and loving my car. You have inspired many of us with your dedication to rebuilding much of your car over the winter. I hope you can enjoy the efforts of your labor soon. I love the new look of your wheels and tires.
Dan
Dan
#102
Thank you Dan for the good words, very much appreciated.
I am out to Hershey Swap Meet tomorrow, and to the opening season of Autocross on Sunday. Can't wait to see what my time difference will be from last year, but with a much more different set up.
