quasi-distributor venting
#32
RL Technical Advisor
Being the cynical engineer that I am, Steve's suggestion begged the question of how the highly expensive rear reflector and light units are affected by ozone?
As I understand it, the feed air from the vent kit escapes from under the distributor caps, so if you are not happy with that personally I would vent to atmosphere at the bottom of the distributor.
LOL,..Interesting observation,....
I must say that after 22 years, I've never seen a LR taillight lens nor rear reflector damaged from ozone. I HAVE seen some that have faded from sun exposure, but those cars came from sunny climates such as Arizona and Southern California.
Still, it may be possible,............
Personally, I have no angst about ducting the exhaust air through there as the factory did as that helps prevent condensation that may occur in cool, humid climates.
#33
I've done some exhaustive research (ok looked it up on wiki) and it seems that ozone makes rubber crack. However, it didn't say anything about being bad for plastic (or then I spose it would be bad for the rotor, dizzy cap and einzbung)
#34
what?
Prior to doppelbunging, one must also inspect both dizzies for rotor direction, as the turbulence created by the rotor disrupts air flow.
As these are hand-assembled cars, some rotors spin clockwise, others counter-clockwise and no guarantees can be made that both dizzies spin the same direction.
