964 Forum 1989-1994
Tire size for 17" Boxster twists
Old 11-02-2011 | 06:39 PM
jtucker's Avatar
jtucker
Default Tire size for 17" Boxster twists
Ok, I've searched the forum and I can't seem to find the answer. I'm getting ready to buy some Boxster OEM 17 " twist wheels, 7" front and 8.5" rear. I assume they will fit w/ no issues. Anyone know what the correct tire size is for 92 C2 coupe? I think I want to stay with the correct rolling diameter, but if there are options to consider...
thanks in advance...
J. Tucker
'92 C2
'08 TT 3.2
Old 11-02-2011 | 07:28 PM
boxsey911's Avatar
boxsey911
Exactly the same as 964 17 inch wheels i.e. 205/50 at the front and 255/40 at the rear.
Old 11-02-2011 | 07:40 PM
jtucker's Avatar
jtucker
Default excellent...
Thanks for your help...
J. Tucker
92 C2 Coupe
08 Audi TT 3.2
Old 11-02-2011 | 08:42 PM
KaiB's Avatar
KaiB
...or move up to a 225/45 up front, a common thing to do.
Old 11-02-2011 | 08:59 PM
jtucker's Avatar
jtucker
Default any difference
in rolling circumference? Any thing else I need to know?
Thanks,
J.Tucker
Old 11-02-2011 | 09:32 PM
Henry964's Avatar
Henry964
I Agree with both my fellow Rennlisters, rears: 255/40x17 front either 205/50x17 or 225/45x17
Old 11-03-2011 | 02:33 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
I ran 17" Boxster twist rims (7 ET 55 and 8.5 ET 50) for years, on the street and track.
I used 225/45/17 and 255/40/17 tires spaced 5mm on the front and 7 mm on the rear (longer studs front and rear for safety).
I had no rubbing issues once I got this setup figured out and no ABS/traction control errors based on tire circumference.
Marc
Old 11-03-2011 | 09:46 AM
jtucker's Avatar
jtucker
Default While I'm asking...
any tire recommendations? Casual street use only, fair weather only. This is my weekend driver.
Thanks,
J. Tucker
92 C2 coupe
Old 11-03-2011 | 10:39 PM
Marc Shaw's Avatar
Marc Shaw
Thanks,
J. Tucker
92 C2 coupe
People seem to rave about the new Pilot SuperSports but I have not tried them extensively myself yet.
Marc
Old 11-04-2011 | 07:58 AM
boxsey911's Avatar
boxsey911
Marc
I'd love to try these too but they're not available over here in 17 inch.
