997 Big reds fit behind RH 18" Speedlines and 964?
Any opinions on whether these will fit behind RH 18" speedline reps and mate properly with 964?
http://www.ebay.com/itm/01-11-Porsch...sories&vxp=mtr
Agent Orange
You're going to have a hard time finding adapters for the front and the rear will be next to impossible. I'm not sure the brake lines are the same either.
Most people go with 993TT/928 S4/965 calipers with adapters and 965 discs in the front and 993 (non-turbo) rear calipers and 964 (as well as 964 RS or 944 turbo) discs. That's a pretty much plug-n-play set up for 964 cars.
Thanks ilko. Seemed like a good price and I got all excited;-)
How much more (than stock) does that set up weigh? Is there a negligible weight gain with the larger disk/caliper combo?
Agent Orange
The front brakes weigh a lot more. Calipers are bigger and so are the discs. It adds a lot of unsprung weight. I would recommend this upgrade for someone who tracks the car a lot and experiences brake fade.
The rears are practically the same weight, only difference is the pistons on the 993 rear calipers are larger.
