964 Forum 1989-1994
unlock car with no keys - mission impossible
Old 10-21-2011, 05:57 PM
Andy Roe
Andy Roe's Avatar
Originally Posted by Frank 993 C4S
Dumb question: Why would you not be able to unlock the car with a key?
I would still take of the wheel and have another look under front left wheel liner for the emergency cable.
You can only unlock the door with the key on the passenger side door - it doesn't work for the drivers door.
Old 10-21-2011, 05:59 PM
Vandit
Vandit's Avatar
I'm guessing if the battery is dead, then the power locks won't respond.
Old 10-22-2011, 03:50 AM
Andy Roe
Andy Roe's Avatar
Yep, thats correct and if you have no battery, the only door you can open with the key is the passenger door. (which is a good thing to be aware of!)
Old 10-22-2011, 05:01 AM
warmfuzzies
warmfuzzies's Avatar
Andy,
I'm pretty sure I've opened mine from the drivers side, but being ROW does that make any difference?
It was a while ago, so my memory maybe playing tricks, and its something I almost want to try now just to see....
Kevin
Old 10-22-2011, 06:14 AM
PehrJ
PehrJ's Avatar
I can open my car from the drivers side with no battery attached. Row car from Germany.
Old 10-22-2011, 12:56 PM
Navaros911
Navaros911's Avatar
Same on my 94 ROW in Bahrain... I can open the door without battery, but it takes some effort compared to doing it with the battery attached.
Old 10-22-2011, 01:18 PM
paolotvl
paolotvl's Avatar
because the only lock that works with the battery down is the one on the passenger's side and that door is against the wall....I can unlock it, I can't open it....
Old 10-22-2011, 01:21 PM
paolotvl
paolotvl's Avatar
I'll try again , but mine gives no sign of working without battery. No resistance, no clicks, it doesn't feel there is anything mechanical moving when you turn the key...
Old 10-23-2011, 10:27 AM
Frank 993 C4S
Frank 993 C4S's Avatar
Sorry didn't know that as my car has a lock on the driver side door too.
Old 10-23-2011, 09:11 PM
Gregg-K
Gregg-K's Avatar
Mine opens with a key on the driver's side too. If yours doesn't, it means the linkage from the key cylinder has become disconnected from the lock mechanism.
I learned this the hard way when I converted to 993 handles on my car, and found the driver's key didn't work when I reassembled the first time ... so, I opened it up, did it again.
Long time ago, but it seems to me it was an adjustable linkage that's held to the lock cylinder with a single screw that clamps the bits together on a spline ... easy to assemble it incorrectly, or have it slip out of adjustment if the screw comes loose.
... Gregg
Old 01-25-2012, 10:55 PM
petercal39
5th Gear
petercal39's Avatar
So...if everything works properly, one should be able to mechanically unlock either door with the key and no battery/dead battery? opposite question: can one LOCK the car from either side with no battery/dead battery? Or is this just a way to safeguard opening with a dead battery.
Peter
Old 01-25-2012, 11:21 PM
90_C2_Cab
90_C2_Cab's Avatar
From what it sounds like the driver door is electronically locked and unlocked with the key and the passenger side is mechanical in nature. Is that what I'm reading into this?
Old 01-25-2012, 11:22 PM
90_C2_Cab
90_C2_Cab's Avatar
BTW - strange thread but an interesting one.
Old 01-26-2012, 01:20 AM
Vandit
Vandit's Avatar
My '91 C2 Coupe is currently sitting in my garage w/ the battery disconnected and the doors unlocked. I just tried to lock it w/ the key on both doors and there is no action taken. I cannot manually lock the driver's door w/ the inside ****. It simply doesn't turn. I can lock the pass. door w/ the inside **** and the key does mechanically unlock the door. So there you have it. If locked out of the car w/ a dead battery, the pass. doorlock should retain mechanical ability to unlock the door and get into the car.
Old 01-26-2012, 07:07 PM
Porsche964FP
Porsche964FP's Avatar
Why don't you just cover the car carefully with a blanket, lie across the roof, reach down and put the key in the lock against the wall?
Quick Reply: unlock car with no keys - mission impossible
