My 94 has a torn steering boot at the rack....I was wondering what is the easiest method of replacement....will the new boot fit over the attachment at the knuckle when separated or do I have to unscrew it at the adjustment section.....would rather not upset the current setting since doing so well.
If I do remember correctly, you need to take the outer tie rod end off to change the boot. An alignment is part of the game. Use a tape measure to get in in the ball park.
If you disconnect the tie rod from the knuckle/axle and if the boot fits over the end then why would you have to redo the alignment if the tie rod is placed back into and bolted down into the same attachment for the axle. There is not a Porsche dealer nearby and given I have seen too many screw up on porsche alignment I would rather not mess with any alignment change/check. If the smaller hole in the new boot can go over the tie rod end/fitting then why mess with an alignment "check".
But if the knuckle end and ball joint are joined together by the tie rod (LH and RH threads), how can you disconnect from the knuckle without "screwing" up the alignment - am I missing something?
I replaced my steering rack boots. I tried slipping them off without undoing the tie rods. The boot does not fit over the ball joint. You need to disassemble the tie rod. While some people have made careful measurements and reassembled without a new alignment. I didn't want to take the chance to screwing up my tires. So I had another alignment done.
+1. I did the measurement thing and my alignment still was off by quit a bit to where my steering wheel was off center. Do both sides while its apart.
1) How do I push the boot into place on the rack side? Do I need to remove panels to get access to the rack or can I just push them in from the fenderwell?
2) If there is some fluid/oil dripping (maybe a couple of drops) after I remove the old boots, does that mean my rack is leaking and on its way to needing a rebuild?
A word of warning to future readers.... I recently replaced both my tierods and tierod boots. Upon assembly I found that the ID of the outside end of the boot wasn't the same as the OD of the new tierods- too big! In my case I cut some short lengths of hose that I had in stock and slipped them over the tierods before putting on the boots, and then used zipties to snug the boot over the hose section. Admittedly, a little cludgy but it gets the job done...
I noticed this yesterday when I first went to test fit the new boots. Then I noticed that there's a rubber piece that fits inside the end of the boot that needs to be transferred from the old boot to the new boot.
I haven't actually installed these just yet, just removed the old boots. I still need to install this piece onto the new boots, then I guess remove that lower aero panel to get them all installed properly on the rack.
I apologize in advanced if this question is confusing and is definitely coming from a novice ( me )
The boot on the passengers side of the steering rack is protecting ?
Does the wide side ( not the narrow side facing the outer wheel ) of this boot ( passenger side ) need to be zip tied or open to elements?
Do parts in which this boot is protecting need to be covered and soaked in grease ?
