switching seatbacks (for that new seat feeling)
I switched, because every time I sat in the passenger seat, I was impressed by how taught the bolsters felt. Basically no one has sat in the seat for the last 20 years, it looks and feels absolutely new.
I started off by reviewing MarkD’s very helpful thread: ~DIY Seat Back Swap – w/pics
(Mark goes into much more detail than I do – awesome thread! Thanks Mark!)
I’ll rely mostly on pictures to show you how it’s done, but it’s a pretty easy modification. Also note: you do not have to remove the seat bottoms from the car to switch seat backs.
On to the pics...
My seats are non-heated and only have manual fore-aft adjustment, therefore after removing the bolts from seat adjustment sliders there are only two connections to unclip before the seats come out. (removing the driver's side floorboard foam is a project for another day)
![](https://lh6.googleusercontent.com/-wtXONeTnGDo/TpR4qq677gI/AAAAAAAAH1M/M2xNr99F3JQ/s912/IMG_5189.JPG)
Remove the plastic hinge cover, two screws.
![](https://lh3.googleusercontent.com/-jHk5zB0PAk4/TpR4oQ89VqI/AAAAAAAAH04/SbhGzzzRTU4/s720/IMG_5182.JPG)
Loosen the two 15mm bolts (apply blue Loctite upom reassembly). Leave bolts in (hand tight) until you are ready to separate the upper.
![](https://lh5.googleusercontent.com/-N6FvCSbsoD4/TpR4hy757mI/AAAAAAAAH0I/uEvNPV8ok00/s720/IMG_5167.JPG)
Carefully slide clip out.
![](https://lh6.googleusercontent.com/-iy_0Y1ri9W8/TpR4hHmpVGI/AAAAAAAAH0E/Nz9Xq8Bnnrc/s720/IMG_5165.JPG)
With clip removed, slide out the little cable release lever arm (note orientation).
![](https://lh5.googleusercontent.com/-_xHKpReppHs/TpR4nWrjE6I/AAAAAAAAH0w/Ekdgv4j0Y0c/s912/IMG_5180.JPG)
Pull on cable to get a little more slack, and then unhook cable from the cable holder (that is built-in to the seat back upper).
![](https://lh3.googleusercontent.com/-_X4Vaoo0RlE/TpR4lF1i3tI/AAAAAAAAH0g/KeqBToT3dGI/s800/IMG_5176.JPG)
With cable release removed, you can remove the two 15mm seat bolts and separate the upper from the seat bottom.
![](https://lh3.googleusercontent.com/-0aVFELhYXsE/TpR4ktR8mTI/AAAAAAAAH0c/74Xiw5PEE5E/s800/IMG_5175.JPG)
![](https://lh5.googleusercontent.com/-_IsbtFIXb3E/TpR4iz9hU2I/AAAAAAAAH0Q/HaXzy0Zs8jY/s720/IMG_5171.JPG)
![](https://lh6.googleusercontent.com/-Gu2335IeqZQ/TpR4jXpYy4I/AAAAAAAAH0U/n5DGy74QI1Y/s912/IMG_5172.JPG)
Time to clean everything while the seats are out.
![](https://lh6.googleusercontent.com/-VE7CkZXif0o/TpR4iQTQavI/AAAAAAAAH0M/WuaEhzouIWY/s912/IMG_5168.JPG)
A couple pictures of the seat height adjustment motors and cables.
![](https://lh4.googleusercontent.com/-G71PUu3sGmM/Tok9UNXK6ZI/AAAAAAAAH18/yRXvYIt8oQc/s912/738.JPG)
![](https://lh3.googleusercontent.com/-Gvz4aShiz9I/Tok9VrPXWvI/AAAAAAAAHhE/HlCJRqJB0GA/s912/739.JPG)
![](https://lh6.googleusercontent.com/-HorlZp09utI/TpR4qMCh4GI/AAAAAAAAH1I/hGHmZmtuhvc/s1024/IMG_5188.JPG)
Seats back in!
![](https://lh5.googleusercontent.com/-8GBrfyj6CKg/TpR4r59JgmI/AAAAAAAAH1U/O6D1nWCU8YQ/s912/IMG_5193.JPG)
As seen in the pictures above, this really is an easy project (that can be done with the seats still in the car). It's taken me a few days to get used to the feeling of the seats...it feels really nice!
On to the pics...
Seats back in!
That's a really good idea, thanks for posting. Especially as I happened to notice this morning that the piping running up the side has cracked on my driver's seat. So if I swapped the backs it would stop that from getting worse.
