The wait is over...Rebuild complete
$21,000 dollars later...Complete rebuild + DM FW, BB exhaust, alternator etc. etc. I picked up my 964 on Friday. I drove it home (ran like a top) and Saturday morning took it out for a drive. When I backed out, what did I see????? Oil drops on the pavers.
I thought must have been some topical oil on the engine after all the work.
Went for a drive to the store....Parked. Sunday morning I moved the car...and now a bunch of oil on the pavers. I looked the under the engine and drip, drip, drip...right off the exhaust.
I drove it to the mechanic first thing Tuesday morning (4th of July weekend). I got off the phone with him a little while ago and the verdict is:
The engine needs to be dropped again, completely torn apart and then put back together to find the cause of the leak. Says the cam housing may be warped and need re-machined or replaced. Gone for another 2-4 weeks.
If you are reading this and thinking about buying a 964, please budget at least 100% the purchase price towards maintenance to actually get the vehicle to a level of respectabillity. I.e. If you want a well sorted 964 but don't have $45,000(purchase + initial maintenance) to throw at one of these vehicles, I highly recommend purchasing another make.
If you get off easier and only spend $10,000 in repairs the first six months or year of ownership, stick the balance in savings for the impending rebuild. You WILL need it at some point.
If oil leaks that would be considered severe on any other vehicle would bother you (and why wouldn't they?), please go foward knowing that your car will be in your mechanics garage more than your own. I.e. if you want the oil leaks repaired prior to driving your newly purchased 964, do not expect to drive it often (ever?).
At this point, were it not leaking directly onto my exhaust, I would simply drive it and get the cardboard diaper most owners have on their garage floor.
It has almost become comical. Clearly, I am not to have this car and I have truly lost faith in Porsche. I am quite confident that even after the added 2-4week repairs, this vehicle will continue to leak oil at some point in the near future. My choice is to accept this or not.
Undecided as I am now so deep into this...
For those of you who are going to question my mechanic, please feel free to do so. However, I would prefer you question Porsche. if you Google "Porsche engine leaks oil even after complete rebuild" you will find that my mechanic and I are in very good, and common, company.
I've owned the car since early May. It has been in the shop all but 5-days.
Thanks Mitch9000. I hope you are right. I am sorry for comming across negative. Truth is, I am simply sharring MY experience with Porsche. Just because my experience, when written in black and white, sounds negative, my hope is that I am in the minority.
Does anyone have a "dry" 964? I.e. Dry for years?
Thank you
Thank you
Hey Guy, this is very unfortunately, I can understand that you would be very frustrated. Obviously something isn't right, and it wasn't detected during the rebuild. Keep us updated on the communication coming from the mechanic, as there are lots of experts here that will be happy to chime in, and provide very sound advice.
As for the leaky engines... mine has never lost a single drop onto the garage floor, before or after my rebuild. I truly believe that all but the most minor of occassional drips can be sorted out. I guess that what I'm saying is that you don't have a 'drip' or a 'leak'.... you have a 'problem' that wasn't fixed correctly.
I know that it sounds like lip service, but I believe that this will all get sorted, and you will be a very happy 964 owner very soon with a very nice car!
I thought that was a lot of coin also, but I've never done it. My car doesn't leak on the floor, but it could be leaking onto the exhaust and burning off.
my other thought is if the OP just bought the car, then the asking price should have been significantly less if a rebuild was called for. And I just remember the OP's other thread where we warned him about PPI.
Thank you
Thank you
I had a couple of leaks on my 964 3.3T, though they only dripped once in a while - cost me €1291 to fix. My friend had a lot of leaks on his 964 and his full rebuild cost him €9000, but he is very happy with the result.
Once the leaks are fixed, probably best to get a leak down test to make sure they did a good job!!
Mine drips alittle, a few drops on the garagefloor after each drive. I dont care tho. As long as it doesn't consume alot of oil while driving I'll let it be.
It's a 1990 C2 with about 86k miles on the clock.
1 Post
Had a similar experience with the rebuild of the 2.7L in my 1976 911; a few days after the rebuild, she started to leak... A LOT. Ended up being an incorrectly installed rear main seal, which was quickly rectified under the shop's warranty. Hasn't leaked a drop since, and that was 5 years ago.
Hang in there, Guy. The leak will be fixed, and you'll go on to years of trouble-free enjoyment.
The engine on mine has been totally dry for the past 8 years that I've owned it, although I have had a few minor leaks from the oil pipes.
I really think that you have just had some bad luck with it and it's not a true representation of the 964 in general.
I'm sure it'll be fine once they've put this right.
