Broken Rocker Arms
Well on a positive note it's only the left half...
Did it fire on a good cyl or was the damage under cranking? If only under cranking the damage could be minimal, three valves, rockers, lap and you're back in business...
Hi Indy. Don't you agree with me? I once bent a valve just by turning the engine by hand when I had not gotten the cam aligned correctly. When the valve head touched the piston, it hit the edge of the head and easily bent the shaft.
If the entire bank was out of time and the engine was started, valves could be slammed back into the rockers by the pistons and those rockers would let go.
Broken Rocker Arms - UPDATE
Well, replaced the rockers and just did a leakdown to see if any valves were bent...... Can't tell!!!
The air is blowing past all 6 cylinders right into the crankcase! Time for some new rings (among other things). So off comes the whole top end for rings, check all valves and replace as needed, install new guides on the newly machined heads, and..., and..., and...$$$$$
For those of you who want to know, we didn't even bother to record the leakdown numbers, suffice it to say, 50% was the good one. Yea, they knew that the engine was cold, and the oil's been out for weeks, but with those values, it wouldn't improve to 95%.
