Pulley shim count- old belt vs. new?
Hi all,
I'm replacing the fan and alt belts on my '90 C4.
There were 4 shims between each pulley half on disassembly; the car came with only those 8. I figure if 4 each was right for a used belt I'll need a couple more for a fresh unstretched belt.
I'll order some new ones, and while they're not expensive, it all adds up. Can anyone comment on how many I should get?
One each?
Two each?
More?
One each?
Two each?
More?
I have three shims under each pulley. According to the PET diagram, each 964 is supposed to have a total of 6 shims.
With your new belts install, how is the belt tension? Too tight?
No install yet; waiting on a fan bearing and alternator rebuild.
I just don't want to get into a situation where a lack of pulley shims keeps the car off the road (yeah.... that'd suck)
From: Philly Area ----- George Washington took a dump in my backyard!
The amount of shims between the pully halves control the tightness of the belt. Less shims in between results in a tighter belt, so a new belt would need more shims than a stretched belt. You store the extras in front of the pully.
Any update on this? My worn belts were running 3 shims on each pulley w/ an extra shim hanging out outside each pulley. I just put it back together w/ new belts and installed all 4 shims on each pulley. The still belts give a bit, but not much. Maybe 1/8" or 3/16". Should I source more shims? I don't want to toast these new belts, or even worse, the fan or alt bearing, because I'm running too much tension/not enough shims.
mine had six each just like PET shows, and ended up with 4/2 2 spares and 4 between each pully halves just like Porsche shows. As note the was a TSB on the Alt pully assembley IIRC one belt is incorrect if you go off the PET number.
Its 6 and 6 for a total of 12 and they are the fan shims are different than the alt shims.
