Bad groaning noise coming from RR wheel area
Gang,
I noticed an eerie noise the other day that seems to be coming from my RR wheel area. I first noticed it doing a sharp u-turn. It has only gotten more noticeable. It varies in intensity but is really noticeable when turning the wheel.
The noise is a groaning or grinding noise, like a low pitched dentist drill. I hear it when the vehicle is stationary and, as I said, especially when turning the wheel. Obviously, I am not confident driving it in this state.
Some background, last time I had the vehicle up on a lift I noticed the RR rubber wheel boot was torn. I am thinking this might be related?
I haven't done any diagnosing yet, but could it be either wheel bearings or a diff problem? What about a leak of some kind? Anyway, I'd love some thoughtful input.
Much appreciated.
ketel
Much appreciated.
ketel
Professor of Pending Projects
Or the power steering pump due to low fluid... check that first.
If the CVJ boot was torn, you might have found the issue already. Take out that shaft and replace the CVJs. Pack those CVJ with good grease before install. You will find it to be one of the measiest job ever done... I still have grease from the last time I did the ones in my 951...and that was more than 10 years ago,
IHI KING!
Check your tire pressure and wheel lug torque too. Eliminate the easy to fix items before doing the more expensive/labor intensive repairs. But I agree, it sounds like a bad CV or wheel bearing.
Burgled
Gang,
Much appreciated.
ketel
Much appreciated.
ketel
Rob
Any red or pink drips or spots on your garage floor? Might want to check the steering rack boots for any fluid leaks and check the hoses and clamps at the reservoir. Clean everything before you add fluid and if you have a leak it should show up pretty quickly.
I had a leaky hose between the reservoir and the pump and my car started to groan going up the levels of the parking garage at the office. The sound was pretty scary, but an easy fix.
Thanks for the advice. I have noticed some drips toward the front of the vehicle. Hoping this is the culprit as the other alternatives get much more expensive.
Any recommendations on good power steering fluid that I can get at a Kragen's etc? Given time sensitivity, I won't be able to order the spendy stuff from Pelican parts, etc.
ketel
ketel
ketel
ketel
Worst case scenario... leak is from the steering rack and you will need a rebuilt unit... so start with the easy option first.
Either way, make sure you remove the drive shaft and at least clean and repack the CVJ with good grease or you will be looking at a more expensive repair if you have to replace the CVJ. At this point you might be able to save them and will only cost you a new boot, grease, and your time.
Cycling the power steering fluid (aka ATF) is never a bad idea. I pump a quart or two through the system when changing the oil. With a 20+ year old system it certainly can't hurt to have fresh clean fluid. FWIW, I use the Castrol equivalent.
