Track Ready!!!
Have fun, practice sphincter control beforehand
V3s should be fabulous on track.
Be safe
Andrew
I'm so lazy now in my old age with a garage at the track, big tow rigs, etc. etc.
I will be there too in my 92 and will post some pics over the weekend.
His comments and questions regarding suspension setup always carried a certain ring of experience and knowledge - yet he never mentioned his experience.
Takes a big guy to do that....
On track the car took some getting used to. I'm so used to the power band, the gearing, the lightness of my 73. The 964 is a different animal. The torque was the first piece I noticed. Awesome. I also noticed that the turn in points and braking points are different. Much later braking, and slightly earlier turn in. It took me 3 sessions to find the appropriate line, and at that point I was flying. Buttonwillow is a fast, technical track. There are 3 tight turns that require balanced power at both rear wheels. I learned LSD is an absolute must. In all the hard right handers I found myself yawing hard left as the power lightened on the right side, so I spent some time sliding the car, and losing distance. I need LSD asap!
The gearing is longer than the early car too, so I was holding the car in lower gears longer and found that this was working best! I was listening to the early car drivers explain their shifting through the course and found is was not making any sense in the 964, so decided to try staying in the lower gears longer. It worked. I was also tracking out wide, visiting the outer limits of the track as Ken suggested. This was working very well. Thanks Ken!Overall the car was fantastic. I was running faster than most of the cars there, which included all early cars. I now know this car is faster and more complete than my 73, and will only get faster with LSD and more seat time. I can only imagine how good this car would be with 200 less pounds weight. Wow!
The best part was that after the track day, at about 3 PM, we loaded the cars for another 300 mile drive north to Monterey, and ahhhhh.... cold AC and some fine music all the way up. What a joy! I love this car!
Kai, I lagged on taking hat photo's. I have 1 good one on the hood of my car at the Treffen. I'll post it up later. Hope you all had a great weekend!
What settings did you run your KWV3 on? The reason I ask is that I decided to firm up the bump settings prior to my own track outing last week. I went from 4 clicks at the rear to 2 clicks and from 6 clicks at the front to 3 clicks. I left the rebounds as they were - 6 clicks front and rear. The new settings produced quite a bit more understeer in the slow corners which I found I could compensate for to a degree by turrning in earlier. However, I still felt that I had to wait a bit longer to get back on the powers so that I didn't track out too early. Hence I'm very interested to compare notes on what you did yourself.
The experience made me think that going firm on the bump settings is only really of benefit on tracks composed mostly of high speed corners. On the plus side, the firm bump meant that the car was the most stable under hard braking that I've experienced from it.
I am running 2-3 clicks off full hard on all 8 settings. I felt the car was very composed, and was solid under full braking. I really need LSD though to fully appreciate this car. I really felt as if the car was performing at 75% of capacity, especially in the tight stuff.
I just posted up a shot of a broken RS drop link I just discovered while inspecting the front brake pads in the garage. I have no idea when, over the weekend, this happened. I suspect it may have been at the track, and may have contributed to a spin I had after exiting a hard left hander onto the front straight. There was plenty of run-off, so really just a dusty mess. I did run the car after that and actually made some adjustments to my driving style and found I was getting faster. Very strange.
I must say that with this 2-3 click set-up, the car performed very well in the high speed stuff.
I'd forgotten you weren't running a LSD. Are you saying you "yawed" under deceleration, or as power was applied?
As I was applying throttle coming out of tight right handers the car would "yaw" left, sliding until the car settled back onto the right side, and would hook-up again. I spent a lot of time correcting, and finally simply slowed down into these corners to eliminate the slide.
What's the latest on your car?
Anyway, pretty surprised you feel you ran different lines. If there's one combo I know back-to-back it's from running the 964 C4 and the '73 S there in '99 and '00. Probably five times I had both cars there as it was when Karen expressed interest in competitive driving, so I'd tow the S and she's drive the C4. Also, during that time my friend had his RSA basically the same as my old one exists now, and another friend had a new '99 996 (stock). I drove the same line for everything, and if I recall on the Bus Stop/Non-Star Mazda config (which is what I think you ran), we were within a couple of seconds with all the cars. Do I keep saying 2:06 for this config? I forget, and I'm traveling so I don't have my records handy.
You DO know you're one of the few to go off on Sunset and not come back around to hit the pit wall? Seen more than one car destroyed there, unfortunately.
I came of on the right side of sunset and had the mind to go both feet in. The car stayed on the right side of the track as the giant dust cloud worked over and through my car. I was told that a sunset "off" normally spits you back across the track toward the wall. I feel lucky
Sadly, no roll bar arrival yet, but she's on her feet (w/ the new wheels) with the engine back in, suspension/brake system in, tranny and LSD (!!!) in and the interior goodies just waiting.
I believe the wing is on, but don't know, as Jeff has been out at the track with clients (!!!) and Stevie can't yet drive for photos.
I have my string gloves, custom shoes and Ferrari red suit all ready...pit crew ('Lil Audrey) has decided she won't overnight in the trailer trackside so I don't yet know who will detail the car nights while I rest.
Life is indeed difficult....
