Changing front brake discs....
As above you may have to replace the wear sensors.
Or the other option is to junk them all together and shorten and short out the wires(pad side of conector) also you can junk the dampers on back of pads.
Not saying you should but it is an option that many people take up.
There is an issue that can happen with 964 brakes that may cause you problems if they have not been sorted before.
There are metal plates lining the calipers that can 'warp' due to corrosion behind them. this make it difficult to fit new pads in.
sorry of you know all that just a heads up
Yes, Junk the sensors, they are PITA anyway and if you are like many, you are visually checking the wear rate of your pads regularly, so no real need for sensors.
I have considered scrapping the mushrooms too. I have heard that if you bed the pads in properly when they are new, the squealing issues are virtually non existent. Please chime in if this is not correct.
took me 20 minutes to slide the pads out.
The dampening plate fuses to the back of the brake pads, so even though the pads were loose and flopping around inside the caliper they would not pull out for the life of me. The dampening plates 'spring/mushroom' was holding them in the caliper. Take a small flat bladed screwdriver on the back of the pad, to pry off the dampening plate before you try to pull pads out.
When loosening the lower caliper bolt, be careful. It is on extra tight and it is easy to slip off and cut yourself on a rusty stone shield.
When loosening the upper caliper bolt, be careful, very close to rigid brake lines.
I reused my dampening plates because Pelican sent the wrong ones. No squeal, with a half-assed bed-in procedure.
Have fun and take your time.
Ditch the brake pad sensor. They usually break when you change the pads. If you trust yourself to routinely check your pad wear, you'll have no problems. He's a helpful link: Ditching the brake pad wear sensors
Also paint your rotor hats with caliper paint (or other high temp. paint), to keep them looking sharp and rust free.
I ditched my mushrooms, I now use the adhesive pads on the back of the dampening plates.
It's a good DIY. I did mine and went to the track a couple days later. No one but myself to blame it it did something wrong!
