Loose axle nut = damage to wheel bearing?
#31
Thanks ThomasC2, put the bolts on last night.
Now all I need to do is torque them, which leads to another question. I know that the rear nuts require ~330 ft-lbs, but when I was tightening them, they seem to have bottomed out when I was just using my 18" breaker bar. This is disturbing since I know that I wasn't applying anywhere near the 330 ft-lbs, and now I'm concerned that torquing them to the 330 might strip the axle threads. Would you have any info on this? Also, seeing that you are a super user and given my lack of forum knowledge, should I post this question as a new thread?
many thanks![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
many thanks
#32
Not to hijack this thread, but wasn't there a locking nut the rs cars used over the first nut? The inner nut was torqued to 330, and then the lock nut fit over that and was torqued to 120...iirc...
Is that lock nut available from Porsche?
Maybe that's the reason for the smaller nut they send now? I have received these smaller nuts as well, and had i never seen the larger nut, they wouldn't bug me. But they bug me. I want my big nuts...
#34
Thanks all for the advice re torquing, but that's not really my problem. I figure that with the 18" breaker bar coupled with my weight, I applied a max of 200 ft-lbs,which was done by just pushing down with my hands/arms, not standing on the end of the breaker bar. My torquing came abruptly to an end at that point - It felt like to me that the nut had reached the end of the axle's threads. My fear is that torquing it to the required 330 ft-lbs might strip the threads on the axle. So my question to all is, am i being too paranoid and should just go with a longer breaker bar to get the required 330, or am I doing something incorrectly or have left something out causing the nut to bottom out too soon. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
93 C4.
93 C4.
#35
Yes. You didn't get to the end of the threads. That's not possible.
You can back the nut off and look. Long and short is, you won't get anywhere close to the right torque with an 18" breaker bar. 330lbs is huge. I use a torque multiplier and a 24" torque wrench when i do it.
#36
93 C4.
93 C4.
I use an m22 I get from a local supplier.
