front hood struts the easier way
as I was about to replace the left side front hood strut after looking at the do it yourself list it said to use a long screwdriver to pry on the strut in an attempt to pop it off the ball...well on looking at it I noticed there is a possibility of some serious scratching from the screwdriver on the painted surfaces (evidently already done to my car once....thank god for touch up paint) I have come up with a MUCH easier solution and its cheap to boot!!!
remove the strut from the upper mount as described...lift hood to take out of hood socket so that the strut moves free...move strut to your left (you are facing the windshield)...take a dowel rod (its perhaps 1/4 inch wooden dowel) and place it as shown between the strut and the metal wall near the lowest end(close to the ball) ...move strut to the right (as you are facing the windshield) and it will pop right off...easy simple and done quickly
picture is after strut was replaced but shows where to place the dowel rod and the right angle for reaching the ball end of the strut
smokey
1990 carrera 2 california coupe
smokey
When replacing mine, I found it easier to get the bottom of the strut secured first, then moving the hood up and down to line up the hole for the pin & clip.
The following 2 users liked this post by newsboy:
9SIX4-C4 (01-21-2021),
Rocket Rob (05-25-2022)
lbpa18 (01-23-2021)
one will not support the hood but replace the passengers side first theres lots more room and it's by far the easiest to do. the hood will be easier to manipulate with your shoulder with one done. drivers side was the hard one to change due to barely enough room for anything.
smokey
smokey
So I have a question; I obviously did something wrong while changing the struts. I must have jostled a wire or some connection loose in those small spaces, because since the new struts have been in, something is draining the battery. I charge the battery back up and everything works great, but within two hours it's dead again. Anyone have any ideas as to where I should start looking/testing? Thank you.
IHI KING!
