Stalling - yes I have that too...
After reading extensive threads on stalling I am now in the quagmire of having to sort out which among a few things could go wrong. Today I will start with the DME relay and cleaning the ISV. Hopefully I sort it out.
Had similar problems with stalling until engine reached operating temperature and cleaned isv but problem persisted and then a few months later xmas tree etc. which eventually caused ecu to malfunction. Changed coils but still the cel would come on until I changed rotors,caps and spark plug & leads and now everything is running perfect.
Check the O2 sensor - could be caked in soot or just bad. I had an issue where the car would stall when I came to a stop. With the trouble shooting help of my mechanic we determined that it was the sensor and it fixed it right up.
I agree in starting with the DME and then the ISV - if that doesn't work I would look to the O2 sensor
Thanks guys.
It seems okay now after cleaning the ISV. Phew. It was getting annoying. Thanks to the archives of this board I was able to trouble shoot.
