964 Forum 1989-1994
boiling hot battery! !
Old Feb 12, 2011 | 03:42 PM
kos11-12's Avatar
kos11-12
Default boiling hot battery! !
Hi guys,
My battery small Oddeseus, is not keeping his charge
at the moment, i went out with the family and when i was disconnected the battery it was boiling hot with strong smell measuring 13. it is going to let me down? Any danger,
Old Feb 12, 2011 | 04:05 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Yes, it is dangerous. You should disconnect that battery as soon as possible
Old Feb 12, 2011 | 04:16 PM
kos11-12's Avatar
kos11-12
Thanks for replying, i disonect it you say once cold i coul drive it for 30 minutes back home or is there a risk of fire
thanks konstantin
Old Feb 12, 2011 | 04:27 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Fire, probably not.
Battery rupturing and spraying corrosive acid everywhere ... yes.
I would replace the battery ASAP and check the alternator as well.
It sounds as though you may have a shorted cell(s) in the battery.
Old Feb 12, 2011 | 04:40 PM
vracer's Avatar
vracer
Have the bat. replaced NOW, not ASAP. Have the votage regulator checked ASAP. I'm not very electrical, but you might be able to do a quickie regulator check with a simple voltage tester.
darth's Avatar
darth
I'm assuming you measured 13 volts while the engine was off and not charging, leading me to believe that it's likely the alternator and in particular the regulator which is at fault and the battery may still be salvagable, provided it is not subjected to further overcharging. Check the battery cells (ie. if it's not a sealed battery) to make sure the water level is good, as some of the liquid may have boiled off due to overcharging.
Old Feb 12, 2011 | 05:16 PM
kos11-12's Avatar
kos11-12
Thanks a lot, we are on the train back home, i will return withlast train with my Audi battery to recover the car
thanks again Konstantin
Old Feb 12, 2011 | 06:42 PM
kos11-12's Avatar
kos11-12
Hi Yes 13 when engine off but when i touch the battery it was really hot, i am on my way my Audi batterie ,
when engine on at tick over should i read 13,5 v ?
Old Feb 12, 2011 | 07:28 PM
darth's Avatar
darth
Just be aware that the Audi battery when you put it in, will be subjected to the same suspected overcharge condition. So I would limit its use to avoid potential damage. Reason I don't suspect a short in the battery is it wouldn't read that hi of a voltage (i.e. 13v) but rather a lower voltage if a cell was shorted, but then again if the short in the cell is intermitten due to vibration, that may explain the voltage reading you're measuring now. Of course this is all speculation on my part and until you have both the battery and the charging system checked out, one can't say for sure what is at fault. The 13.5v charging voltage doesn't sound too far out of line, it could be higher and it tends to contradict my suspicion of over charging. Who knows, maybe once you put the Audi battery in everything will be fine, let us know.
Old Feb 12, 2011 | 10:28 PM
altarchsa's Avatar
altarchsa
I had a battery do this in my 75 Targa and it was just the battery. Replacememt solved all.
I would disconnect it now. If it's that hot, there has to be a possibility of explosion.
Old Feb 13, 2011 | 04:09 PM
kos11-12's Avatar
kos11-12
hello guys,
it was the battery cells that were cooked, the actuall battery case was distored, the Audi (100 1994) battery is same spec as the 964 so no probs, it was cold as ice when arrived home, voltage when engine on @ tick over was 14V, I am still wondering what could have cause the Odyssey PC 680 to go that way...I had it since a long time in the car, went for long trips with it ect, I would say the only issue was to test it on regular basis when I was not driving the car for a long time and charge it, i never let it down lower than 9 V,
but one think I left it with a garage to do my brakes conversion and they run it down to 3 to 4 V and try to boost start it, then charge it several times, I wonder if they cooked it by overcharging it, do the boost start could have damage it ? I had this battery since 2006, I don't think it is to long for that type, it suppose to work for 10 years, a least the one I bought at the same time for my bike is still in perfect condition
Konstantin
Old Feb 13, 2011 | 05:00 PM
darth's Avatar
darth
I like it when there's a happy ending I'd partly attribute your battery's early demise to past abuse. They really don't like to go down much more than a cell voltage.
Old Feb 13, 2011 | 06:49 PM
Laker's Avatar
Laker
Thanks for posting an update. I have good luck with those Odyessy batteries on my motorcycle. Even when not taking care of it over the winter. Also had good luck with customer service. I would call / email them. You never know and might just get a replacement.
Old Feb 14, 2011 | 01:34 PM
kos11-12's Avatar
kos11-12
well... I had them since 2006 so they probably would not replace it...
probably went to low after all ...
Konstantin
