How about a "tuned" exhaust?
Tuned systems generally work best on open systems. I.E. header + straight pipe out the back. No mufflers, cats, resinators, or bends.
They really work best on two-strokes.
To my ear, one of the best sounding systems I have heard was one a 3.0L with SSI's and a Dansk sports muffler, nice growl, very different from our engines with cat/primary bypass or cat/secondary bypass.
I just bought a set of 993 heat exchangers that I will fit to my car, thought I would try to hook them up to either a Dansk or a Monty muffler and see what kind of sound will emit from a system like that.
Ahum....do a search on David Vizard exhaust science, exhaust tuning on 4-stroke engines has such strong effects/potential DV goes as far as calling it the 5th stroke.
In my experience any reasonably well designed equal length header system (including SSI's) has the potential to make more power than a stock cat-free 964 system. Two examples below, one back-to-back test of a 964RS on 9m Motec with a set of B&B headers & the other a similar back-to-back of a 964RS 9m Motec +3 (billet heads, 3.8, cams, Motec) with 9m headers.
The well-known tuners are in this thread, good to see that! I think it is very logic that non equal lengths of exhaust sytems (for porsche this means headers) for left and right cilinder bank are a better solution than the 964 uses.
( I did a lot of tuning on 2-strokes, which is much less complex than 4 stroke and exhausts are a more important factor to consider on 2-stroke, but from what I can apply to 4 stroke is that unequal length exhausts is very suboptimal)
RL Technical Advisor
Due to local noise restrictions for many years, we are required to muffle our exhausts and as such, have a header/muffler system that makes very good power on these engines. Naturally, its not for everyone due to noise levels, however one needs to understand that there are many options for street and track cars.
Two strokes AND four strokes both benefit from a well designed exhaust.
