Heater problems
Heater problems
I have had my heater CCU repaired in the US and it has just been returned in working order with a life time guarantee.
I plugged it in the car and it now lights up as expected, only I still have the same problem.
WHAT DO I CHECK NEXT.
When I turn the ignition on I get front and rear fans on, on full and cannot change that.
When I turn the ignition off and pull the key out it carries on and i have to full fuse 1 to stop them.
Lee
Lee
IHI KING!
There was a wiring change in 1991 for the CCU harness. It allows you to use a 993 CCU. What year car do you have and what model CCU?
Sorry if this has been asked before. If you have the link to an earlier thread, please post it.
The last time I saw that behaviour from the fans it was the final stage relay at fault. I have a spare which I think is good - pm me if you want me to post it for you to try.
Cheers mate,
I have a spare my self I think. It is the one on a metal plate which fits just in front of the servo's.
I'll give it a try and let you know what happens.
Lee
Lee
That's the one. I remember you saying that you had picked one up but I guess you haven't changed it yet.
Steve
Just fitted the other final stage relay that I had.
Made no difference what so ever.
either thats faulty as well or where do I go from here? any ideas
lee
lee
Of course, the second hand one you bought could be a dud but let's forget about that now because what concerns me more is the other stuff i.e. the CCU doesn't appear to be giving you control of the servos or the fans. What is the part number of your CCU? As Rob mentions, there are different ones...a non aircon, RHD 964 made in 1991 or later should have unit 964.659.046.01.
The reason I'm asking this is that your car may not have the original CCU because the original could have stopped working a while ago and the PO may have swapped it for an incorrect unit.
The later cars had a small wiring modification to the plug. I wonder if removing the wiring modification from a 92 car will allow a pre 91 CCU to be used with a later car?
To check if you have the wiring mod on your car remove the plugs from the back of the CCU and open up the larger 35 pin connector. The wiring mod for later cars is identified by there being wires connected to pins 19 and 1* (they're next to each other at one end). Pull out the wire in pin 1 and tape it up and plug your CCU back in and see if it works.
This is only a suggestion of what I would try in your case...I have no idea if my logic will work...but have my fingers crossed for you.
*ealier cars that use the 964.659.046.00 CCU only have a wire in pin 19.
Rob - unfortunately not, I dont know any one else with a 964.
The only other thing I could do would be to visit the local breakers in leeds to see if they would allow me to try one.
Right i'm off in the garage in about an hour to try the wiring idea.
will let you know.
cheers for all this guys
will let you know.
tried it - no change unfortunately.
guess I need to get hold of a 01 part number or the 993 version to see if it makes a difference.
Suppose I could always sell my unit. I suppose it would be a good buy as it now comes with a life time warranty.
lee
lee
