964 Forum 1989-1994
Hesitation
Old Jul 26, 2010 | 11:15 PM
tonyc's Avatar
tonyc
Default Hesitation
Apart from the rear spoiler not working, I noticed a 2 second hesitation while driving today. It done this to me before. No power for a couple of secs then when I press the accelerator i get a short rush of power.
Any suggestions. Will pass this one to my mechanic when I see him today.
Tony
Old Jul 27, 2010 | 07:19 AM
tonyc's Avatar
tonyc
The mechanic has come to have a look and has noticed my alternator's gone. So this could have been the hesitation problem. T
Old Jul 27, 2010 | 09:40 AM
olly964T's Avatar
olly964T
Wouldn't have thought that would explain the hesitation with the throttle response would it?
Old Jul 27, 2010 | 02:10 PM
RichieRoo's Avatar
RichieRoo
Does the hesitation correspond to any specific driving condition? It's a common fault that the car hesitates immediately after coasting downhill with a closed throttle.
Rich
Old Jul 27, 2010 | 04:39 PM
ginch's Avatar
ginch
Yeah mine seems to do this a bit as well. Its not so much coasting downhill as it is just driving along at a steady speed (usually driving around 35 MPH), then rolling on the throttle and experiencing a hesitation for a second. What causes this?
Old Jul 27, 2010 | 11:45 PM
tonyc's Avatar
tonyc
Yes, this is the problem, was coasting through a tunnel, and the previously down a slope just to find an unresponsive gas pedal.
Old Jul 28, 2010 | 03:41 AM
Solitude's Avatar
Solitude
Change DME relay fist. Fuel pump if it does not work.
Old Jul 28, 2010 | 04:12 AM
ACSGP's Avatar
ACSGP
Mine started off like that, and progressively got worse, to the extent that it prob only fired on half the cylinders and went into limp mode. Exacerbated when it got hot.
The problem were the coilpacks which showed they were normal at the shop through the system check.
Changed them both, and car's fine.
Old Jul 28, 2010 | 09:16 AM
ThomasC2's Avatar
ThomasC2
If it always happens at the same rpm it could be a "bad spot" in the air flow meter mechanism.
Thomas
Old Jul 28, 2010 | 10:54 AM
aeroman's Avatar
aeroman
Man of Way Too Many Avatars
Is this at WOT or any amount of throttle? If it is WOT then check the WOT switch.
Old Jul 28, 2010 | 11:52 AM
olly964T's Avatar
olly964T
I remember readnig (on this forum, i think) about issues when engine is cold and car is taking off from the lights or something, but dont know if this would be the same as when the engine is warm and going car already moving.
Old Jul 28, 2010 | 08:12 PM
Snowhead's Avatar
Snowhead
Tony C, I had a similar problem and I called the previous owner who told me to check the 3rd plug lead below the power steering fluid reservoir as it leaked slighty onto the lead causing a short. I dried if off yesterday and bingo no more hesitation.
