Punching a hole on oil Filter vs Loosening filter housing vent?
1 Post
I'm changing oil on my 964. I've read two different ways to get most of the oil out of the filter and filter housing.
Question: Which is really better?
1.Punching a hole in the filter?
OR
2.Loosening the vent on the backside of the oil filter housing?
OR
Neither?
Once I punched the hole and what a mess, never again..
the trick is to drain the tank and case then undo the filter, my theory and not scientific but "feels better" this way
Punch a little hole on upper side of the filter, then undo the plugs on the case and the tank. This will "suck" most of the oil out of the filter/filter house. Finally put a piece of tape over the hole and undo the filter. It's easier than getting a good grip of the bolt inside the rear fender where it's dark and dirty.
Thomas
Thomas
I have done both... when I punch a hole in the filter, I also do it first, thus causing more of the oil to be drawn out. Then I take a piece of tape and cover the hole before pulling off the filter. I actually like undoing the bolt in the filter console, but it takes a little more time as you really need to clean around the bolt before loosening it - keeps the dirt out of the threads so you get a clean seal when re-assembling.
When I do the bolt, there seems to be less oil in the console... and it is recommended in all the manuals.
BTW, if you spin the filter off using a plastic bag, it can capture all the drips. I have done oil changes where I don't lose a drop- victory! ...and others that were total nightmares when I didn't get the filter back on tight enough.. big big mess. I believe it has as much to do with karma as anything else...
You can also use compressed air from a blow gun to blow into the hole in the filter which eliminates the mess. Do it after the tank has been drained though.
I have not found it necessary to punch a hole in the filter, if I remove the plug on the filter console. Just be sure to clean the area around the plug before removing. I have no problems with drips/gushes when removing the filter.
YMMV
YMMV
Keep in mind not all cars have the vent plug on the filter console. Some of the early cars did not - my
'90 doesn't. YMMV.
It's probably not documented as to when Porsche used up the non-vented console inventory.
'90 doesn't. YMMV.
I use a few layers of paper towels under the filter, let everything drain first, then spin the filter off. I've drooled a few drops a couple times, but I've got the hang of it now and I generally don't spill a drop.
So, with that in mind - yes, I agree that punching a hole in the filter will have glorious results in reducing oil spillage from the filter, if you do not have a vent plug in the filter console.
So you can imagine how confused I was when changing the oil for the first time and I couldn't find the damn plug.
So now I just do the same as Oracle & Bearclaw.
Just did mine a few weeks ago and used the Small hole in the oil filter method. Worked great no oil was spilled. Tape though is a must over the hole. I used a nail to punch the hole about 4mm wide. Not large at all just enough to let the air in and the oil flow. -D²
"Just did mine a few weeks ago and used the Small hole in the oil filter method. Worked great no oil was spilled. Tape though is a must over the hole. I used a nail to punch the hole about 4mm wide. Not large at all just enough to let the air in and the oil flow. -D²"
This is the method I use and not a drop of oil is leaked into the engine compartment.
