Hello (intro) and help..
I have been lurking around for some time now, reading, searching etc.. thought it was time for a proper introduction.. with a request for help..
I am Jason, live in Surrey UK and about 3 months ago I bought this nice 964, I am well happy..
Its not perfect but I bought knowing I can deal with the smaller issues 1 at a time, whilst hopefully using regularly..
Only thing spoiling the party is that I seem to be suffering from some bad electrical woes. The symptoms are when driving the radio suddenly cuts off, then the engine starts misfiring and all the dash warning lights go red, sometimes the tiptronic freezes in D and wont move over to manual till the engine is restarted. These episodes can last from a second ie just the radio cutting out, to 30+ seconds where the car is really jerking around. It happens totally randomly, I drove to work the past 2 days clocking over 100 miles with nothing, then this morning it happens almost every time I use the car. I have looked at various Christmas Tree effect threads and done the following..
Replaced the DME, Ignition Coils, Dizzy caps and dizzy rotor arms and stripped and cleaned every earthing I can find in the bonnet area, but its still acting up.
both dizzy caps were real bad
Also, might be related but twice when I have tried to start the car has been completely dead electrically, no ignition lights, no alarm responce and the central locking did nothing off the key (as in wouldn't lock or unlock when the key turned) - almost as if the battery is disconnected. A minute later everything back to normal.
I don't mind getting stuck in, but I am running out of ideas.. can anyone help?
cheers Jason
(also posted on 911uk)
I have ordered the vent kit, as one isn't fitted. Should be here tommorrow..
when not being crippled by these electrical issues the car runs smoothly and you would suspect any problem at all..
Other than that - worn ignition switch maybe? I had to have mine replaced because it sometimes used to illuminate all the dash lights as I closed the door (with the keys in my hand!). I don't think it caused me running problems, but it certainly could.
Transmission earth strap, where is that? do you have a pic??
ignition switch?? like this below? is this behind the dash and how difficult to fit??
http://www.design911.co.uk/fu/prod83...4---993---944/
Hope that helps!
Derek
when I when to lock the car, there was no power to the keylocks, I could turn the key but it wasnt firing the mechanism or locking either door.
battery terminals rechecked, all clean good strong connections.
does anyone know if/where there are any earths under the dash or in round the front fusebox, I canot see it being anything else.. unless there is a main power relay??
Aside from checking the earth connections etc. as mentioned above, you might want to pull the central electric (fuse box) board and look around for any buggered up wiring. Likewise check the engine compartment wiring for any signs of damage.
If that's Horizon Blue, it's beautiful and very rare. Your car is a carbon copy of mine except someone has installed the steering wheel on the wrong side!!
