964 Forum 1989-1994
bleeding brakes. How do I remove the inner debirs screen?
Old Jun 11, 2010 | 07:01 PM
ttAmerica RoadsterAWD's Avatar
Default bleeding brakes. How do I remove the inner debirs screen?
Trying to pull out the inner white screen tub without braking it. I see a notch on it and a notch on the outer surface, but it will not slide up or unscrew!
Anyone????
Old Jun 11, 2010 | 08:05 PM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Are you referring to the brake fluid reservoir? There is no need to remove the inner portion of the brake reservoir - just screw your power bleeder on and clamp the overflow hose.
Marc
Old Jun 11, 2010 | 08:12 PM
Hi Marc. thanks. I've been reading here its better to remove the old fluid with a syringe on the brake reservoir so I don't push old fluid thru. Problem is that white screen tube will not allow my hose to go to the bottom of the reservoir......
Old Jun 11, 2010 | 09:23 PM
DAVISRILEY's Avatar
DAVISRILEY
Whenever I have taken mine out, I kind of fold it in on itself a little bit to get it out. It's a bit scratched up, but I never worried about it.
Old Jun 11, 2010 | 10:48 PM
Thanks. Just bled right thru the old stuff!
Old Jun 12, 2010 | 12:15 AM
Marc Shaw's Avatar
Marc Shaw
Ahh...I just use a turkey baster to suck as much of the old out as possible.
Marc
Old Jun 12, 2010 | 12:18 AM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Talking
Marc
Wife just hates it when I do that... for some reason it screws up the taste of the turkey...
Old Jun 12, 2010 | 12:19 AM
Hi Marc, yeah, I used a syringe, but that inner debris screen only goes to about 1/2 of the reservoir and can't get to the lower half without removing it..... Well, I just hooked up the Motive and went to town. Problem is I've gone thru 3/4 full Motive and still have spongy brake......
